Old 11-07-2021, 10:29 PM   #1
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
6th gear slower?
so i am aware that i might have a tuning issue...
but does anyone else feel like 6th gear was better n/a at low to mid rpm?
just asking to see if its just me or this is common..
i could understand why if its because when not in boost you don't have similar intake runner characteristics as n/a but in 6th gear boost should happen right away right? as it is immediately under load.
i am assuming this is something i can fix in the tune...
and my tune is sort of a long story,
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned
biker2k is offline   Reply With Quote
Old 11-08-2021, 01:28 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Do you have some data logs you could post up?
Old 11-08-2021, 06:32 AM   #3
biker2k
biker2k's Avatar
i could get some
Old 11-08-2021, 08:23 AM   #4
s346k
s346k's Avatar
Drives: like an old lady
how much boost is it making at the rpm you're turning? i imagine the car is making very low boost numbers and seeing much less timing at sub 2k rpm vs na.
Old 11-08-2021, 08:36 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
My guess is your tune has a lot of timing yanked out of it in the low/mid range area of the high octane spark table. Seems to be common with many tuners and FI setups.
Old 11-08-2021, 02:51 PM   #6
biker2k
biker2k's Avatar
that would explain alot if true
Old 11-08-2021, 04:47 PM   #7
Joshinator99
Moderator
If only there was something available that you could use to record what’s happening for us….
Old 11-08-2021, 06:05 PM   #8
KingLT1
KingLT1's Avatar
Old 11-09-2021, 06:34 AM   #9
biker2k
biker2k's Avatar
i just haven't gotten a chance but i will thanx
Old 11-09-2021, 09:41 AM   #10
biker2k
biker2k's Avatar
here are some logs
i believe this tune is on speed density
turns out i had a vacuum leak at the purge valve when i got this tune....
i got a second maf tune to fix original tune not knowing there was that leak and then i discovered i also ha d a new and much bigger leak where my catch can line was cut in 1/2 below airbox where i couldn't see and then car was maf tuned that way... all leaks were my fault but nonetheless i dont think i have had an clean slate tune, car runs better and more consistent obviously since i fixed them and turns out car runs best with original tune. so i have so many questions and feel bad for my tuner and myself, in the end i think i need a retune maf style with everything right, anyway this sixth gear thing just had me thinking and thought i would see if that's normal going from n/a to s/c..
says the hpl file is invalid for upload
Old 11-09-2021, 11:50 AM   #11
Joshinator99
Moderator
here are some logs
Upload it to Google Drive and share the link.
Old 11-09-2021, 12:55 PM   #12
biker2k
biker2k's Avatar
https://drive.google.com/drive/folde...-H?usp=sharing
hows that
Old 11-09-2021, 07:11 PM   #13
KingLT1
KingLT1's Avatar
It's timing related just as I thought. You are seeing single digit timing(3-8 degrees) on tip in the high load(0-6psi) lower rpm(18-2200rpm) areas of the timing map(bottom left quadrant). That will make the car feel anemic part throttle.
Old 11-10-2021, 05:25 AM   #14
biker2k
biker2k's Avatar
and you're thinking that's its the tuning not car doing it because it needs to and if so would it be safe to bump the timing there?
i did notice no knock retard if I was looking at it right..
also looking at the other logs it doesn't look like its doing on them ..
