![]() Drives: 2019 Camaro SS Join Date: Aug 2019
Decided to run meth on my bolt on NA car
Was finally able to add Methanol to my bolt on only car over the weekend. Had to mix it with e85 and 93 octane but still made decent numbers with what we were able to do. On e85 I made 487rwhp and with the meth mixture we made 525/504 to the wheels. Yes that was SAE not STD. The Car went a 11.21@124mph at my local track before the last round of mods. 11.21 was e85 only for fuel. I have since dropped 300lbs off the car, added my circle d converter, bigger cold air kit, solid motor mounts, lighter rear wheels, and have since added the meth for fuel. Will be adding Lighter brakes on all 4 corners, maybe a different intake Manifold, drag seats and upgrade the fuel system to run straight meth. May hit capital city dragway or atco before the end of the year to see how much better she runs now.
Timeslip
![]() Drives: 2018 2SS 1LE 416 NA Join Date: Feb 2021
Hey LeoDirt, im also interested in Meth injection, My Car is an 18 1LE,Manual, FBO, stage 2 cam and tuned the Vengeance Racing on E-85. Since I have the ZL1 low side, do you think in still have enough fuel pump to run meth?
nope you wont have enough. Im in the process of working with lonnies perforamce to build me a fuel system.
BAMF SS
I guess dropped dropping 300 lbs, switching to m5, converter, intake, and switching to poverty stars didn't help, because it looks like fasterproms had your car at dragway 42 and it ran an 11.34 @ 124?
I don't know where you get 525 rwhp out of a trap speed of only 124 I went 10.9 @124 at keystone raceway Park, at full weight, with only 460 rwhp.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
#6 | |
#7 |
2Spdsy
Drives: 2021 Camaro LT1 A10 Join Date: Mar 2016
Wow . 6.8 at only 98mph. That’s pretty Efficient. That car has some good low end. So I’m trying to understand how meth would work on a bolt on car ? I know it’s cold but it’s not like our inlet temps are that hot to begin with. On a boosted car it’s easy to understand but on an N/A car what would be the advantage . I know meth is a fuel but you also need more air to ignite it , if there’s no boost then how do you make power?
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i believe op is in the left lane.
i've wondered how the car with make so much more on methanol, as well. all i can figure is if you can get more fuel in there and cleanly burn it, more power will follow.
#9 |
2Spdsy
S346k. Oh shit your right . My bad . I thought with all those mods and weight reduction he would easily be in the 10’s.
#10 | |
#11 | |
![]() ![]() Drives: 2019 2SS Camaro Join Date: Apr 2012
e85, ethanol, i think 35% oxygen meth 40% plus some I forget maybe 46% then, nitro flips the script nitro has no afr because it brings it on oxygen and the more u put in the more will burn and make power. 52% ox maybe The limit being hydro locking. The ogs of oxygenated fuels ha. Oxygenated race gas just means it has some alcohol blended into it to make more power. Fuels that make the most power are also in that order. e85 methanol nitro. I dont know where nitrous oxide falls probly between meth and nitro. But as an add on as it again brings its own oxygen into the combustion process. |
#12 | |
#13 |
![]() Drives: Chevy Camaro SS Join Date: Nov 2019
Who’s tuning the car? Numbers look solid though and seems right for what was added.
2017 1SS:Hi-Ram, FBO, OTR ram air, Circle D converter. Previous PB: 11.07 @124 1/4 7.1 @100 1/8 1.6 60’ w/2” longtubes, 95mm hi-ram, OTR ramair, flex fuel |
#14 |
