Old 10-20-2021, 07:40 PM   #1
jpalermo
Drives: 2021 Camaro LT1
Carbotech XP12 Pads cracking after one track day…
I put Carbotech xp12 pads on the front of my LT1 and they cracked all the way thru in one track day at watkins glen… anyone else have a similar experience with these pads?
Also any other recommendations for a track pad? Im on the 4 pistons
jpalermo is offline   Reply With Quote
Old 10-21-2021, 08:09 AM   #2
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Interesting, never had this bad of an issue with mine. I've used many sets of 8/10/12 compounds. I would see some cracking starting at the pad surface and propagating to the backing plate vertically, but not across like in your picture.
I currently use Hawk DTC-60 pads with good success. The bite is a bit less than XP12, but overall they aren't a bad pad at all.
My personal favorite is PFC 08 or PFC 11. Hard to find for the 1LE though.
Some others had good feedback for Raybestos ST-43s. I have experienced parts of the pad chunking off though.
5.M0NSTER is offline   Reply With Quote
Old 10-21-2021, 10:33 AM   #3
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Looks like those pads are all used up thickness-wise anyway (as far as HPDE tech inspection is concerned). Did you get them pre-bedded?
FWIW, I've found the '12' level to be less durable than the '10', but if you're going to stay with Carbotech (or G-loc) you probably want to step up to the next higher compound.
Norm
Old 10-23-2021, 12:56 PM   #4
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
How where the temps on the brakes? Did u have the extended cooling plates and removed dust shields?
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
Joey Soul is offline   Reply With Quote
brakes, track
