Old 09-09-2021, 08:15 PM   #1
SoCal Racer
Drives: C4,C6 Z06,Silverado,'17 Red Hot ZL1
Red Line 75W90 GL-5 Gear Oil
I am having a shop prep my ZL1 for a track day. since the car will already be worked on, I asked for a differential fluid change and they noted on their estimate...
Obviously, I know the Red Line brand,...but I know throughout this forum that people insist to use the OEM AC Delco which I understand. Just curious if anyone has tried this and if there were any thoughts, good or bad....thanks
SoCal Racer is offline   Reply With Quote
Old 09-09-2021, 08:21 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Running it in my SS rear diff currently. Not sure the difference (if any) vs a standard ZL1 diff, but I’ve always had good luck with Red Line stuff. I’m not quite stock, either.
Old 09-09-2021, 08:27 PM   #3
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Amsoil Severe Gear is #1 based on standardized tests I've seen
ZX-10R is offline   Reply With Quote
Old 09-09-2021, 08:39 PM   #4
Z OH 6
Drives: 2024 CT5-V Blackwing
I've only used it in my 892whp Hellcat but it performed just fine for over 3 years.
Old 09-09-2021, 08:49 PM   #5
SoCal Racer
Thanks...I figured Red Line would be fine. I have used it in many vehicles previously, but when searching in this forum people always direct you to use OEM. It's odd because aftermarket is typically more expensive than OEM, but not in this case.
Old 09-09-2021, 08:54 PM   #6
Joshinator99
Moderator
Old 09-09-2021, 10:39 PM   #7
SoCal Racer
I would think most aftermarket fluids would be better, but if you read through the threads in this forum they mostly advocate OEM. If aftermarket fluids were not atleast as good (if not better) than OEM, I would think they would be out of business...
Old 09-10-2021, 04:19 PM   #8
ZX-10R
ZX-10R's Avatar
They are better, no question - but it's "OEM or your car will blow up, warranty voided, etc etc" type dogma parroted by ignorant people - the science is irrefutable (standardized testing, and to lesser extent, UOAs)
Same with oil filters
Old 09-10-2021, 04:50 PM   #9
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
I do recall that when I mentioned that I use Motul Gear 300 LS in my eLSD, a bunch of people told me not to. I personally don't have any issues with the fluid, and I do take mine to the track.
The only reason I can think of is maybe some are concerned if there is enough limited slip additive in some of the aftermarket fluids, but as long as you get something designed for clutch-based LSD, then they should have enough additive in it to prevent any issues.
It looks like Amsoil Severe Gear 75W-90 will work, though I personally do not feel like messing with adding their Slip Lock additive(how much to add, if I need it at all, etc.) when I can just buy Motul Gear 300 LS and it's already got the additives in it. Same with Red Line Gear Oil, it already has the friction modifier in it.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 09-10-2021, 05:20 PM   #10
AZ_1LE
Drives: 2019 ZL1 1LE
Pretty sure you dont have to worry about having friction modifier in the fluid because the clutches in the eLSD are sealed off and are lubricated by separate fluid you never really need to touch. So you basically just need some good gear oil in there and that's it.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
