Old 09-01-2021, 04:12 PM   #1
SDF62
ZL1 1LE Wheels On An SS
Like the title says....has anybody ever run this set-up on an SS? Thanks for any input.....
SDF62 is offline   Reply With Quote
Old 09-01-2021, 07:24 PM   #2
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
I’m sure someone has, I don’t know what the offset is they might poke a little given the ZL1 fenders are a little wider. 2 deg of negative camber might fix that though. Biggest concern would prob be clearance with the strut. I’m sure there are post on here of people trying, I’d dig around a little.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 09-02-2021, 04:00 AM   #3
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Did you try doing a search
https://www.camaro6.com/forums/showthread.php?t=502166
Old 09-02-2021, 05:48 AM   #4
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Originally Posted by carguy55 View Post
You just had to be that guy.
Search function of most forums including this one is nearly useless.
Spaceme1117 is offline   Reply With Quote
Old 09-02-2021, 06:57 AM   #5
SDF62
I appreciate everybody's input...thanks. The answer was kind of what I figured but just wanted to confirm.
Old 09-02-2021, 05:18 PM   #6
carguy55
carguy55's Avatar
Took 5 sec on Google to do:
camaro6 ZL1 1LE Wheels On An SS
lol
Old 09-03-2021, 06:22 AM   #7
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
Yep, that's why you search from Google.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 09-10-2021, 04:14 PM   #8
MMC(SW) Retired
MMC(SW) Retired's Avatar
Drives: 2021 Chevy Camaro LT1
I am running 20x10 and 20x11 MRR M650s on my LT1 with 285-35s and 305-30s front and back. I'm also lowered an inch. No rubbing and tucked nicely inside the wheel wells.
2021 LT1 A10
Borla S-Type, CAI Intake, BMR Springs
MRR M650 Wheels Nitto NT555 Gen 2 Tires
GM Splitter and Rear Spoiler
MMC(SW) Retired is offline   Reply With Quote
Old 10-08-2021, 07:56 PM   #9
jones1090
jones1090's Avatar
Drives: 2020 Rally Green Metallic 1SS 1LE
I run a set of 19" Apex wheels in ZL1 1LE specs for track use (same as the ZLE OEM backspacing, width and offset) with 305 front 325 rears on my Non-Mag ride 2020 2SS with the SG3 GM lowering suspension and have had no issues with rub anywhere front or rear after multiple track days. The fronts do have some poke, but they tuck in the fenders at the top with -2.5 to -3 of camber. I did grind a small amount off the struts as people had discussed on here, but do not think I even needed to do that as I am running camber plates so not much camber dialed in at the spindle anyway. The other thing I had seen online was concern about a harness rub on the rear which has been a non-issue for me either, maybe someone who knows more can chime in if the harness in question has been relocated on newer models?
2021 Camaro 1SS 1LE A10 - RIP
2020 Camaro 2SS A10 - Sold
2016 Camaro 2SS M6 - Sold
2001 Camaro SS M6 - Sold
1996 Camaro V6 Auto - Sold
1986 Corvette 406ci M6
1967 Camaro SS350
jones1090 is offline   Reply With Quote
