Old 07-19-2017, 11:49 PM   #1
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
MOUNTED!: ZL1 1LE wheels on SS 1LE (photos)
So I was lucky enough to be able to try a set of ZL1 1LE wheels on my SS 1LE tonight to test the fitment. A few people, including myself, were very interested to find out the specs of these wheels to determine if they would fit cars with mag ride, well, we know the answer now.
The answer is two fold, and not quite as straight forward as you may think. If you are running aggressive front camber (i.e. anything more than factory) they WILL NOT fit without a spacer. I say again, they DO NOT fit if you have an aggressive front alignment without the use of a 5mm spacer. I currently have -2.6* of camber and the wheels would not bolt up. I had a 3mm spacer laying around and it allowed me to fully bolt up the wheels, however, the lip of the rim just ever so slightly rubbed the strut. I made a u-turn in the street and the metal to metal rub was very noticeable during the turn, fine when driving straight. So what does this mean?
The answer is that if you do not track your car and you maintain the factory alignment specs, these wheels will clear just fine. If you run any added negative camber to the front, you will need a spacer.
For clarification the wheel specs are:
19x11 et11
19x12 et41
As these share the same front wheel specs as the Z28 wheels, which we have seen before, just like those they poke out quite a bit on the front. Add an extra 2mm from what you see in the pictures below to imagine how it would look with a 5mm spacer. Personally , if I were going to run these they would be a track only wheel and the poke wouldn't matter. I'd be hesitant to run these as a street wheel though, as you will get quite a bit of road grime being thrown at the paint.
One solution is the addition of the C7 Z06 fender flare like a fellow member did on his SS 1LE, this would nearly cover the poke at the top of the wheel. Another, more expensive option would be to try to fit the wider ZL1 fenders. Of course, this isn't an issue if you already have a ZL1. We already know how these wheels will look on a ZL1... *cough* ZL1 1LE... *cough*. However , for you ZL1 owners keep in mind that we do share the same mag ride struts, so you too will need a 5mm spacer, thus it will probably poke a tad on your cars as well.
To reiterate, below is an SS 1LE with -2.6* F camber and a 3mm spacer.
seanblurr is offline   Reply With Quote
Old 07-20-2017, 06:26 AM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Cool.
Info helps for ordering custom wheels as well
Old 07-20-2017, 09:43 AM   #3
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Very nice. Thanks for doing that. Another option now would be to use the Moreno Motorsports camber plates. You could probably get away without a spacer. I agree with you that the poke is too agressive for my taste on the street but if there is no clearance issue with the fender lip on the track, it's an option.
Eric SS is offline   Reply With Quote
Old 07-20-2017, 11:50 AM   #4
Ak1LE
Drives: 17 white 1LE
WHERE are these wheels available!?
Ak1LE is offline   Reply With Quote
Old 07-20-2017, 12:10 PM   #5
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
Nice job Sean !! great post.
Carlos_MRRWheelsInc is offline   Reply With Quote
Old 07-20-2017, 05:04 PM   #6
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Yea wow, pokey outie, just like the ZL1 1LE. Thanks for sharing!
Forum Sponsor That GM Parts Guy has them listed on his website. HERE
Old 07-21-2017, 05:30 AM   #7
R.C. Collins
R.C. Collins's Avatar
Drives: 2017 Camaro
Agreed. Definately needs flares or wider fenders.
R.C. Collins is offline   Reply With Quote
Old 07-21-2017, 11:37 AM   #8
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Do you think the rears would rub if the car was lowered? Also are the MAG shocks physically larger in diameter than non MAG struts?
I'm thinking of doing OEM 19x12 rear and MMR 19x10.5 front.
WhiteNight is offline   Reply With Quote
Old 07-22-2017, 12:31 AM   #9
OminouSS
OminouSS's Avatar
Drives: Red Hot track candy
Been up in the woods with no service for 3 days and you drop this bomb? I figured 3 rims were lost in transit.
What does the adj camber plates do for this equation, if anything?
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
OminouSS is offline   Reply With Quote
Old 07-22-2017, 01:07 AM   #10
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Adjustable camber plates would allow you to run minimal camber using the factory camber bolts, thus giving you more clearance between the rim and the strut. You could then get this camber back through the use of a camber plate.
Old 07-22-2017, 01:12 AM   #11
Eric SS
#becauseracecar
Eric SS's Avatar
You could probably run these and camber plates and still get probably 3.5 degrees all day long. 1.5 degrees at the knuckle and 2 more at the tower?
Old 07-23-2017, 02:13 AM   #12
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Thanks for the information.
It's a bit hard to tell how much is the poke from those angles do you have any pictures from the front and rear?
glamcem is offline   Reply With Quote
Old 07-24-2017, 04:10 PM   #13
MatthewAMEL
MatthewAMEL's Avatar
Haven't there been multiple guys saying the Z/28 wheels bolt up with no fitment issues?
Are you saying the front's rubbed because you are running more camber than suggested by the HP Supplement? If you use -2, will they rub?
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 07-24-2017, 06:31 PM   #14
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
It's all about the backspacing. These wheels have 9mm less offset than the OEM Standard ZL1 and SS/1LE wheels but they also have 4mm more
backspacing. That puts the back edge of the rim almost exactly (within 1 mm) of the back edge of a 10" rim with a 25mm offset. Those of us running these wheels have issues with aggressive negative camber as well.
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
