Old 08-03-2021, 11:19 AM   #1
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Flex Fuel Kit Part Numbers
I am trying to put together a flex fuel kit and my cheap ass is going to buy the parts individually. Does anyone know for sure the part number for the fuel line most of the "kits" use?
So far I have:
GM (AC Delco Flex Sensor) - PN: 13577429 - $50 - - -gmpartsdirect
GM (AC Delco Fuel Line) ---- PN: 22912576 - $32 - - -gmpartsdirect
Gen5DIY Flex Fuel Harness - - - - - - - - - - - $78
for total of $160. Nearly $100 cheaper than any of the "kits" online. I don't believe there is any reason to put big bucks into the components as a "kit". I'll make sure to do the tune right.
Jaxcam02 is offline   Reply With Quote
Old 08-03-2021, 12:01 PM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
I'm entertaining adding such a kit too. Pretty sure I'll need a high side pump also.
So far I have:
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 08-03-2021, 12:08 PM   #3
Jaxcam02
Jaxcam02's Avatar
I think you'll need to know the average ethonol content of the stations in your region. I think going to e60 is fine on stock fuel system.
Old 08-03-2021, 12:21 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
I've got a low side pump and assume I'll need a high side and injectors too. I'll check on local ethanol content.
2020 ZL1LE A10.
Old 08-03-2021, 12:24 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Yes, they look correct but keep the E content to E50 or so. E60 on some cars is too much. I just installed the kit on my '21 ZLE and tuned it. The fuel line needs to be tucked behind the supercharger with the sensor. Otherwise pretty straightforward just like any of the online tutorials. Watch pin 38 location as there's a little black plastic plug preventing the insertion of the pin.
Old 08-03-2021, 12:39 PM   #6
Jaxcam02
Jaxcam02's Avatar
I've heard e50 too. What do you use to keep track of the E%? Looking for either a mounted gauge or using torque pro and am not sure which way to go or even what specific gauges are good.
Old 08-03-2021, 01:27 PM   #7
Jaxcam02
Jaxcam02's Avatar
Just made the order. For anyone who searches this thread in the future.
Sensor and fuel line bought on eBay.
Went with gen5diy harness.
Ended up saving 115 bucks buying things seperately
Old 08-03-2021, 03:27 PM   #8
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
It’s not the same content across the board. It totally depends on your mods and your altitude. Your tuner needs to look at your injector head room and fuel pressures with the car operating via data log. I’m able to run e70 in Denver. My tuner tested my car at this blend.
Also in CO we have an “e85” FB group that monitors and posts availability and pump content.
CW3SF is offline   Reply With Quote
Old 08-04-2021, 10:13 PM   #9
Stephen12ZL1
Drives: '21 ZLE A10
I had the torque app with the correct PID for it to work with the cheap android dongle...I just recently installed a Banks iDash gauge which has ethanol content with the AEM air/fuel.
Old 08-05-2021, 09:00 AM   #10
Jaxcam02
Jaxcam02's Avatar
If you don't mind, what PID equation did you use?
Old 08-05-2021, 09:09 AM   #11
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I had a little Kroger gas on top of gas monkey's home delivery sercice they usually deliver 90 to 91%
Old 08-05-2021, 08:51 PM   #12
Stephen12ZL1
Drives: '21 ZLE A10
https://www.g8board.com/threads/etha...ndroid.255489/
From that thread...works perfectly
Old 04-09-2023, 01:14 PM   #13
LloydK
Drives: 2020 SS Camaro A10
Just bought the gen5diy harness, where does it plug in for power ?
LloydK is offline   Reply With Quote
Old 04-09-2023, 08:05 PM   #14
Terry the Tramp
Drives: Camaro ZL1
Terry the Tramp is offline   Reply With Quote
