Old 07-22-2021, 02:28 PM   #1
Skyman2112
Skyman2112's Avatar
Drives: 2016 2SS blue velvet w/blk stripes
Question Weird steering issue
Like that title says, its weird. When im turing the wheel at slow speed like an intersection or parking lot, the wheel seems to chatter/pulsate as im turning it to the left. As if the actuator is not moving smoothly, but jerky instead.
Didnt see any other posts about this, just steering dying. Been doing it about a year and seems more noticeable on loose pavement or grass. Do you think my actuator is having issues and sticking?
Skyman2112 is offline   Reply With Quote
Old 07-22-2021, 02:56 PM   #2
Jb54
Drives: 2019 Camaro SS M6
Your 2016 has electronic power steering.(EPS). It doesn't use fluid. Instead it uses an electric motor to power the rack and pinion. I think your electric motor is wearing out and needs replaced.
Jb54 is offline   Reply With Quote
Old 07-22-2021, 03:02 PM   #3
Skyman2112
Skyman2112's Avatar
yeah i remember now its electric. Sounds like the motor is having issues then even with only 18k miles. Weird how it only does it turning left, (extending the shaft i believe).
Old 07-22-2021, 03:40 PM   #4
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
There was a recall on the steering rack for 2016. Did you have your's fixed. It has something to do with a bolt. I would check your VIN and see if the recall was ever fixed.
dpevans is offline   Reply With Quote
Old 07-22-2021, 03:43 PM   #5
Skyman2112
Skyman2112's Avatar
Ill check it out thanks!!!
Current mods. Rotofab CAI, Speed Engineering Long Tube Headers and plug wires w custom tune. Shock tower brace, ground effects, OEM brake air ducts and splash gaurd delete, 275/315 tires on 10 and 11 inch MRR wheels.
Old 07-22-2021, 11:49 PM   #6
Pupilbone
Pupilbone's Avatar
Drives: 2019 Crush ZL1 M6
Great tip. Would be interested to hear how this works out.
#SaveTheManuals
Pupilbone is offline   Reply With Quote
Old 07-23-2021, 10:37 AM   #7
ctrlz
Anyone have specifics on exactly what is (potentially) wrong with the power steering? I think the recall just says, "may lose power assist." I think I read at one point that the position sensor in the unit might fail. I have not been in a hurry to have mine replaced (2017 2SS).
Old 07-23-2021, 05:19 PM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Here's the recall (2017):
https://static.nhtsa.gov/odi/rcl/201...9V086-8145.pdf
Old 07-23-2021, 05:28 PM   #9
I was going to suggest that, too, but it states model year 2017 only, and OP has a 2016, so I'm not entirely sure it's applicable.
CR says the impacted build date range is from July 1, 2016 to May 19, 2017, which looks suspiciously close to the entire 2017 model year to me.
Old 07-23-2021, 06:32 PM   #10
dpevans
It effected my Camaro and it was built in March/ April 2016.
Old 07-25-2021, 09:29 AM   #11
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
I had a similar issue with my 2015 Canyon. But as soon as I turned off the truck and turned it back on, it was fine. The steering wheel was turning as if it was indexing in multiple positions instead of turning freely. I couldn't make it go straight, it was either slightly to the left or to the right. No "inbetween" position. This happened around 6k miles ago and never done it again... Hopefully it's the same for you.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 07-26-2021, 11:51 AM   #12
Skyman2112
Skyman2112's Avatar
I entered the VIN number but didnt show anything. Seems like the actuator is probably going bad. Cant find any other info on this.
jerky steering, rack and pinion, steering
