Old 07-05-2021, 10:36 AM   #1
Nightfire
Drives: 2018 Camaro 2SS
GM CAI and 103mm TB
Hey all, I have a question if the 103MM TB with fit the GM Performance CAI. I know the roto Fab would be better suited but I have the GM one know and just trying to see if it would fit or what I would need to make it fit. Thanks in advance!!
Nightfire is offline   Reply With Quote
Old 07-05-2021, 12:42 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Measure the ID and OD on the tube for the GM, then call the TB manufacturer and ask for an adapter.
EDIT: now that I look at the tube, you may not be able to bend it far enough out of the way unless the adapter is very short. Might be better to sell it and just move up to the Big Gulp (presuming you're tuned).
Old 07-05-2021, 04:57 PM   #3
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
What other modifications have been done or are planned for the engine?
Old 07-05-2021, 08:08 PM   #4
Puddin
Get a regular Roto-fab if you're still na and if you have a pd blower do a big gulp.
Old 07-05-2021, 09:11 PM   #5
Nightfire
I ordered Headers and the MSD Intake. Was going to do the 95mm but not even sure that would fit. May need to pull off and measure.
Old 07-05-2021, 09:14 PM   #6
Nightfire
Will the regular Roto need an adapter or will it just fit? What about JLT?
Old 07-06-2021, 12:38 AM   #7
Puddin
Regular rotofab fits without any adapters. Jlt should also fit but not much info on how well it performs. Rotofab is going to be what most tuners recommend as it's pretty much the gold standard around here. I run a msd with a 103 with the standard rotofab. If they had a big gulp for na cars I'd run that but the don't and they don't have any plans to make one as I have asked them numerous times about it.
Old 07-06-2021, 11:05 PM   #8
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
I ran the GM and RF with a 95mm. You won’t be leaving much on the table by choosing the 95 over the 103 with that set up.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
