Old 05-18-2021, 09:34 AM   #1
Camaro#7
Drives: 2021 Wild Cherry ZL1 1LE, A10
Loud Popping noise
I currently have a 2021 ZLE with the A10. Just 2 weeks ago I experienced what I thought was the infamous break issue in the front end. I took both front tires off cleaned and put a thin layer of grease on the mounting surfaces of the wheels and hubs. It seemed fine for a few days until I actually had a chance to drive the car for about 20 miles and the sound showed back up. It actually sounds like a spring or something binding up in the front when I turn left or right and at all speeds. Comparable to a spring seating or unseating itself. I have also looks at both shocks and all the steering/sway bar end links and have found nothing loose. Any ideas would be great. Side note: The car only has 1400 miles on it. The noise is loud enough when my wife drove it she said it scared the crap out of her the first time it did it.
Camaro#7 is offline   Reply With Quote
Old 05-18-2021, 09:38 AM   #2
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
ck the X brace that goes over the motor
Old 05-18-2021, 09:41 AM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Wheel-hub deposits are a clicking while low-speed turning.
The clunk while turning over bumps is sway bar end links.
Really loud bangs can be strut top bolts.
Old 05-18-2021, 10:13 AM   #4
Z OH 6
Drives: 2024 CT5-V Blackwing
Did you take it to the dealer? It should be under warranty.
Old 05-18-2021, 12:15 PM   #5
gtfoxy
Drives: '21 Wild Cherry ZL1
Every once in a while I hear a clunk from the front coming out of my drive. It’s sloped with a small dip where the street gutters are & Im usually turning to the left.
Think that might be the end links?
Old 05-18-2021, 01:05 PM   #6
AZ_1LE
Drives: 2019 ZL1 1LE
I'd definitely have the dealer look at it. It kinda sounds like maybe the top strut perch is binding and releasing.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is online now   Reply With Quote
Old 05-18-2021, 01:55 PM   #7
Camaro#7
Thanks all. I have checked all the typical things on it. This is my 2nd ZLE and 3rd ZL1 overall and have never heard this one. AZ_1LE might be on to it. It certainly sounds like something to do with that and only does it once it warm so that would make sense. I live in one of the worst places for dealerships and wanted to exhaust all avenues before I make a 3 hour drive to get the car somewhere that is halfway reputable.
Maybe I'll try dropping the DSSV shock out and see if I see anything. It is odd that it happens at any speed once it's warm and you can get it to do turning left or right with little steering input or as much as you want.
Old 05-18-2021, 02:51 PM   #8
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
I think that might explain the noise I've heard, how does that cause a click and where do I clean it?
SFV1LE is offline   Reply With Quote
Old 05-18-2021, 03:13 PM   #9
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I've heard that "spring/sprong" sound especially after jacking the car and going over the first uneven bit of my driveway. I feel like it is 100% normal and everything is tip top after I checked it over. Dealership is going to be "lost in space".
Old 12-07-2021, 09:08 AM   #10
stormtrooperSS1le
Drives: 2017 camaro ss 1le
Sorry to revive this but did you ever figure this out? Mine does this when COLD and the first turn of the wheel always makes a binding thud sound. Hopefully something that can be easily replaced?
stormtrooperSS1le is offline   Reply With Quote
