Old 05-05-2021, 10:23 AM   #1
PROMETHEUS
PROMETHEUS's Avatar
Next Winter Project/Headers
Being in the northeast, like most, my car gets put away for most of the winter. For me, that is a great time to work/upgrade the car. So with the idea "it is never too late to start planning"......
Need suggestion/ideas/real world experiences on....
Best Coating on Headers to reduce heat build up in the engine compartment.
Thanks in advance, Tony
Old 05-05-2021, 10:30 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
I had my Kooks coated with the Jet Hot ultra 2500F coating. I'm super impressed with it, its very durable and it keeps the heat inside. Its actually cooler in my engine bay with the coated headers than it was with the stock manifolds by a significant margin. I've had them on for 6 months and they still look new.
Old 05-05-2021, 10:31 AM   #3
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I just ordered ARH headers from RDP Store and had ARH install an extra bung for my wide band and then ceramic coat them before shipping out to me. Not the cheapest way to go but definitely the highest quality workmanship and the ceramic coating looks almost like stainless steel. I couldn’t be more pleased with how they look. I want quality in my build.
CW3SF is offline   Reply With Quote
Old 05-05-2021, 11:38 AM   #4
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Check out https://headershield.com/#how-does-it-work
I just had mine done locally, they turned out great.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 05-05-2021, 12:08 PM   #5
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Only thing I'd recommend is Swain Tech coatings. My ARH headers have been coated and 3 years later no flaking or chipping. Engine bay heat was reduced significantly. If you stop the car, pop the hood, you will feel more heat from SC than headers.
https://swaintech.com/
Old 05-05-2021, 12:14 PM   #6
Z OH 6
Always heard good things about Swaintech but do they actually have any colors other than white? That being said, the Jet-Hot 2500 coating is top notch as well and comes in a few colors for those that don't want white.
Old 05-05-2021, 02:59 PM   #7
20Bluezl1
+1 on Swain Tech I bought my 2" ARH from RDP and had ARH weld an extra bung. Then I shipped the headers to Swain Tech and not a beautiful finish but it works amazing.
Old 05-05-2021, 08:13 PM   #8
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
I haven’t seen anyone go with shorty headers yet. Like them?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 05-06-2021, 01:09 AM   #9
swisstyphoon
I had no other choice, long tubes are illegal here.
The outlet diameter is larger than the stock manifolds.
But the quality of the BBK shorty's really sucks!
Hopefully I have my build finished within the next few weeks and find out how they perform.
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
