Old 02-25-2021, 05:25 PM   #1
gtfoxy
Drives: '21 Wild Cherry ZL1
Two 10L90 transmissions listed for ZL1’s
I was snooping around GM parts direct looking at transmission parts. I noticed they list two 10L90’s. One code 9lgj, the other 9lfj.
Does anyone know the difference? Was one for verts & the other hard tops maybe? Or one for US markets & other non-domestic?
Just curious.
Also, $2,700 for a new one. I really thought it would be more.
Old 02-25-2021, 05:44 PM   #2
Nightfall ss1le
Nightfall ss1le's Avatar
Drives: 2020 A10 ZL1 1LE
I believe the ZLE has a different transmission pan than the regular ZL1. It’s also calibrated slightly different, but I doubt it would be a different part number for that.
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD
Nightfall ss1le is offline   Reply With Quote
Old 02-25-2021, 05:48 PM   #3
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
The RPO codes are different starting in 2020
Other than the pan (thx for reminder Nightfall) there is no physical difference between ZL1 and ZLE transmission, but I understand there is a programing difference
2019 and earlier transmission:
MGL : TRANSMISSION AUTO 10 SPD, 10L90, GEN 1
2020 + transmission:
MI4 : TRANSMISSION AUTO 10 SPD, 10L90, VAR 1, GEN 1
I agree, $2700 seems cheap.
Old 02-25-2021, 06:56 PM   #4
Nightfall ss1le
Different code due to the TCM changing in ‘20?
Old 02-25-2021, 07:34 PM   #5
gtfoxy
I could see that.
This was listed under ‘19 model year. Maybe early & late model year.
Might have to check my build codes to see which one mine has.
Old 02-26-2021, 08:11 AM   #6
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Slight gearing difference on the ZLE.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 02-26-2021, 09:44 AM   #7
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
the 20 up has a different filter
I didn't know there was a gearing difference............ I thought they were the same
this is what i have in my notes for the A10 in the LT4 cars
Final Drive: 2.85
1st: 4.70
2nd: 2.99
3rd: 2.15
4th: 1.80
5th: 1.52
6th: 1.28
7th: 1.00
8th: 0.85
9th: 0.69
10th: 0.64
Reverse: 4.87
Old 02-26-2021, 09:46 AM   #8
parish8
Drives: 17 SS a8
I was shopping for an a8 and they were cheap too... until you add in the required core charge. I don’t remember the number but it was up there and made the price make more sense.
Old 02-26-2021, 11:30 AM   #9
Only on the Tremec, the 10L90 has the same gearing in both
Old 02-26-2021, 12:50 PM   #10
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Don't believe it's changed any gear ratios
https://www.camaro6.com/forums/showthread.php?t=584316
2016 1LT v6
- Totaled
Happiness: Infinite
Old 02-26-2021, 05:44 PM   #11
Pendelton
Drives: Camaro 2017
ZLE has slight gear shifting.
Pendelton is offline   Reply With Quote
