![]() Drives: 2019 ZL1 Join Date: Oct 2019
Will 2009-2013 ZR1 carbon rotors swap to the G6 ZL1 OEM hats?
Most of the posts say to use the C7 Z06 rotors (394x36mm) or C7 ZR1 rotors (394x36mm with additional heat treating) but when I checked the C6 ZR1 rotors, they are also 394x36mm.
Just curious, since you can swap the OEM G6 ZL1 hats/hardware to the carbon rotor rings from a 394x36mm rotor for a C7 Z06/ZR1, would the C6 ZR1 work too in that way? They are notably cheaper on Ebay. 1369.99 vs 1599.99 each. https://www.ebay.com/itm/2009-13-Che...gAAOSwhOVXfUUg |
![]() Drives: '18 ZL1 1LE Join Date: May 2020
You've peaked my interest. Subscribing to see where this goes...
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
I thought the pad shape was different on the J57 brake? It’s not the ZL1 pad shape.
Can’t use the CC rotor with a standard pad.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
I believe all the GM carbon fiber rings to be the same dimensions no matter the application...even the '14-'15 Z/28 are the same so logic dictates the C6 ZR1 would also work. The correct hats for application can be swapped to any of those rings.
#5 | |
![]() Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
The C6 ZR1 and the C7 Z06/ZR1 all share the same caliper as the ZL1 the only difference being vented pistons on the vette’s. Being that the rotor is the same diameter and thickness I see no reason a ZL1 hat wouldn’t make it compatible with our cars. Yes they do use different pads but that is for the ever so slight increased radial depth of the CCM rotor from our 390MM to 394. This wouldn’t cause a need for a new caliper.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
#7 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
So, if I am reading this thread correctly... Any Vette carbon rotor could conceivably fit our ZL1 hat... The Calipers will work as is... We only need a different set of pads...
So, which pads would be best for this?
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#8 |
Correct, theoretically any 394x36 CCM rotor with our hat should fit on the car, I would probably just get OEM pads from the Z06/ZR1. They do a fantastic job on those cars already and dust is a non issue with CCM so no reason to go aftermarket for performance unless you find a better bargain.
#9 |
![]() Drives: 2017 Camero ZL1 Join Date: Nov 2015
Here's a good thread on Carbon Ceramic brakes for these cars. I know Rabbit swapped C7 Z06s on and they fit OEM ZL1 calipers. $2900 and saved 34 lbs.
https://www.camaro6.com/forums/showt...5#post10677505
2017 ZL1 A10
Dyno/Quarter Mile/Dragy 9.71@141.2 MPH so far. 2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold. |
