Old 02-20-2021, 11:47 PM   #1
Calubi
Drives: 2017 1SS 1LE
Street testing car with 4pt half-cage/rollbar
After researching the pros and cons of moving to a 4pt rollbar with race seats and 6pt harness, my understanding is this is a bad idea for a car that sees street use due to the risk of contacting the roll bar behind the seat if an accident occurs. So for those of you that have such setups, how do you "test" the car between track events?
I'm thinking of things like brake bedding and making sure the last round of repairs are good. Or even trying to diagnose a new noise. Basic car maintenance. Do you remove the rollbar? Just accept the risk? I'm genuinely curious. The articles and threads I've read talk about daily driving (and why not to do it), not the feasibility of taking the occasional drive to verify the car runs fine.
2017 Camaro 1SS 1LE - Stock for now
2015 VW Golf R DSG - GIAC ECU/TCU tune
Calubi is offline   Reply With Quote
Old 02-22-2021, 08:24 AM   #2
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
I drive my car all over the place with my roll bar In the car in the summer. I live 30min from my local track and drive car to and from events. Just watch out for other drivers that's all.
It's all a personal preference if you want to risk getting into a bad enough car accident where you will get tossed around the car to actually hit your head on the bar behind you.
That1guy_tim is offline   Reply With Quote
Old 02-22-2021, 08:33 AM   #3
Choda
Drives: Turbo 6.2
You hit a point a lot of people dont even think about.
I had a 10 point in my last car because it needed it at track. Driving around in the summer traffic with a dozen steel tubes is not the greatest idea. Esp when I know I never really synched in my harness like I did while racing. These new car can go pretty fast with out having a cage. I know for sure, I'll never add another cage to a street car. Even with swing outs and a custom cage. Also keep in mind these newer cars have multiple air bags. Bars might get in the way of them working properly.
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 02-22-2021, 10:55 AM   #4
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
I had a 4-point in my 5th gen, it was my daily. To make myself feel better, I padded the bars near me and prayed that I wouldn't need them.
Keep in mind that race harnesses are not DOT legal for the street and you should always wear neck protection with harnesses. I used the OEM 3-point when on the street and relied on the airbags and padding. Fortunately, I was not in any incident.
Old 02-23-2021, 05:45 PM   #5
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
With a full bucket race seat and harness, I don't actually know how much of a risk there really is... There would have to be alot of flex in the seat during impact. I'm far from an expert though.
Mine occasionally sees street miles.
seanblurr is offline   Reply With Quote
Old 03-08-2021, 08:54 AM   #6
Blast2hell
Drives: 2020 ZLE Rally Green A10
I know where mine is relative to me, I'd have to depart my front seat and be sent to my rear seat to hit my 4pt. Is that possible to happen? Sure anything is possible. Statistically improbable I would lean toward assuming you are still wearing your standard seatbelt and aren't driving insane. Still, the impact required to move me around like that may argue you are better off having the 4 point to give yourself a better chance.
2020 Rally Green ZLE A10
(SOLD)2017 NGM ZL1 A10 Built 3/31
Sebring Best Lap Time 2:29 Video
Roebling Road Best Lap Time 1:25 Video
Blast2hell is offline   Reply With Quote
Old 03-08-2021, 12:06 PM   #7
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yea im still trying to figure out if i want oem zl1 seats or a full cage and seats and harness setup
Old 03-09-2021, 12:08 PM   #8
TrackClub
TrackClub's Avatar
I happened to survive an accident, in which my car was rear ended at hiway speed (while being stopped due to an accident in front of me). I was thrown back with incredible force then forward when my car collided with a wreck in front. Trust me, if i had a single steel tube anywhere in the car my brain would be sprayed all over. And dont think for a moment that some padding will make steel "soft" at high impact.
Accidents are called accidents because nobody can predict them. They happen in a split of a second. If we could somehow "see them coming" there would be no accidents.
To me this subject is binary:
1) full on race car: zero street
2) dual purpose car: full oem safety (which is damn excellent these days).
Old 03-09-2021, 12:22 PM   #9
That1guy_tim
Drives: Camaro 1ss
maybe if you had a half cage in your car the rear end wouldn't have pushed so far forward?? ........ (just playing devils advocate here for conversation)
Old 03-09-2021, 12:59 PM   #10
TrackClub
TrackClub's Avatar
Maybe. Maybe not. Cars are designed to have crumple zones on purpose. Even Nascar Cup cars. To me, aftermarket cages installed on street cars are highly questionable especially given how and where they are connected to the frame (and often not welded). I also think, that too often, folks assume that any aftermarket roll bar/cage is vastly better than specifically designed airbag oem system. Ive seen street cars turned into "race cars" completely pancake upon a roll over because of poor choices of frame connections. Etc.
Another issue is that many folks incorrectly attach harness belts making them effectively useless. Even some shops that attach them have no idea how to do it properly. No matter what track i go to, i always seem to find a car or two with this issue and an owner completely unaware of it. Because they trust their fave shop to to the right thing. And effectively drive a car with ZERO protection. This is not just limited to amateurs btw. Ive seen cars at NASA and SCCA events with this problem.
I guess what i am trying to say is two fold:
1. Dont drive a car with steel tubes anywhere inside the cabin without a helmet. Period. Full stop.
2. Dont assume any aftermarket safety solution is somehow automatically superior to eom solutions (which are designed and tested under strict conditions and then rated by an independent gov body).
Enough said from my armchair Cheers!
Old 03-09-2021, 01:17 PM   #11
TrackClub
TrackClub's Avatar
Here's an example of improperly attached harnesses. Can you spot the difference between driver and passenger sides? Hint: a passenger would exit thru the windshield like a high powered projectile.
Note all the safety inspection stickers
Old 03-09-2021, 01:28 PM   #12
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Wear a helmet all the time... risk mitigated.
ing for grip.
http://www.motorsportsne.com/
Old 03-10-2021, 06:22 AM   #13
That1guy_tim
Drives: Camaro 1ss
Yeah that harness is not going to stay tight at all! I will admit I almost left my harness wrapped like that the very first time. Something told me ehhh that doesn't seem right. research lead me how to properly wrap it.
I will also agree it's crazy the things you see pass thru "tech".
I appreciate your responses TrackClub. always highly informed and I usually learn a thing or two reading your posts.
Old 03-10-2021, 09:02 AM   #14
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
I prefer to see harness around the bar harness installation when possible.
That's too many possible failure points. Welded tabs, the bolt, the bracket w its 2 cent spring latch.
ing for grip.
