![]() Drives: 2017 1SS Join Date: Jan 2021
Rough idle, Stalling out after CAI Install
Recently had a shop install headers and flex fuel kit on my car. Drove it home from the shop no issues at all. A few days later I found a Rotofab dry intake online and installed it myself...
Now the car will start up just fine but after a few seconds it starts to shake, idle very rough and eventually stall out. I'm in the process of remote tuning it with Pray but only have the base tune he sent. I've double checked all the hose connections, disconnected my battery for a few minutes, MAF is installed the correct direction but still has the same issue. ![]() Any ideas on what else I should look at would be greatly appreciated! |
Thank you Al Oppenheiser!
A few guesses:
1. You have an air leak between the MAF and the throttle body. 2. You didn't plug the MAF back in, damaged it, or damaged its wiring. 3. Did you check codes? |
#3 | |
I don’t have any codes related to the MAF. If it was an issue with the MAF there would be a code correct? |
![]() Drives: Chevy Camaro Join Date: Nov 2021
Were you able to resolve your problem?
PCV connection to intake is behind the MAF, therefore any leak will bring in unmetered air.
See pix: https://www.camaro6.com/forums/showthread.php?t=572714 |
![]() Drives: 2017 Camaro ss Join Date: Jun 2020
Are you sure the MAF is installed with the correct direction of airflow going through it. Thats exactly what what mine did when I was trying to put it back together really quick and wasn't paying attention. It would take two minutes to flip it and see.
#7 |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
You probably still have an air leak at one or multiple connections. I have a Rotofab, installed it correctly and all the clamps were tight. I had to replace the clamps with much higher quality Mishimoto clamps. No problems since.
#8 |
![]() ![]() ![]() Drives: 2023 2SS Convertible Join Date: May 2009
Well, he logged on in April. Maybe he has his notifications on?
-Geoff
