![]() Drives: N/A Join Date: Feb 2020
Intake Tube PCV Connector Box Part Number?
Hi,
I recently bought an SS 1LE and the previous owner installed a KN Blackhawk intake. I'm wanting to go back to stock for autocross classing reasons. I purchased a gently used stock intake on here, but it didn't include a part I need. On the stock intake, there is a small black box that connects the pcv hose to the intake. Seen here: The KN intake doesn't seem to use this part: When doing some more digging, I found some place that calls it a 'water catch fitting': Does anyone know either: The part number? or Where I can find one? or If you have one for sale? My fear is that it is considered part of the stock intake tube but the GM parts diagram doesn't seem great. |
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
Thread resurrected for those that might need to replace
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit Last edited by SSShark; 06-20-2025 at 09:31 PM. |
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit |
