Old 02-15-2021, 08:22 AM   #1
Vileintent
Drives: 2017 Camaro ZL1 A10
Advice for cutting valve covers
I'm doing a 2650R swap on my ZL1 and I don't have access to a bandsaw to cut the valve covers.
Any advice for something else I could use and not make a mess of it? What did other folks use to cut theirs?
I could buy a bandsaw but it would probably be the only time I ever use it. I also considered just buying new lower profile covers, but I was wanting to stick with the OEM baffling under the assumption it might be better than aftermarket (+ it's cheaper to keep them or buy a bandsaw).
Thanks
2017 ZL1 Black, A10
Build: Magnuson 2650R, 103NW Throttle Body, Rotofab Big Gulp, Kooks 2" headers, Catless, AWE Touring exhaust, JRE Smooth Idle Cam, Katech Oil Pump, Elite Catch Can, JMS Fuel Booster
Vileintent is offline   Reply With Quote
Old 02-15-2021, 08:34 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
cut off wheel for a drill or die grinder?
Old 02-15-2021, 01:55 PM   #3
laynlo15
Drives: 2022 Lt1 A10
If you have a solid work bench you could also clamp the valve covers down tight and use a sawzall or a cut off wheel as King said. They are cast aluminum so pretty easy cut off.
Old 02-17-2021, 09:31 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I used a sawzall and cleaned it up with a Dremel. It was pretty easy. Just make sure to clamp the valve cover down firm, and move it around as you need to so you're not in awkward positions. I would, also, tape it off REALLY good and clean it REALLY good, too, before assembly. I think it took longer to cut the valve covers than install the blower, HA. I cut the VCs a week before installing the blower, which made the blower swap really easy and, actually, enjoyable. I don't think I swore once. HAHAHA
'20 ZL1 Black "Fury"
Old 02-17-2021, 08:37 PM   #5
Vileintent
Thanks all, glad to hear it's not a big deal to do. Appreciate the replies.
Sent from my SM-G986U1 using Tapatalk
2017 ZL1 Black, A10
Old 03-15-2021, 02:11 PM   #6
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
radz28, is there a template or guide on what should be cut off? I'd like not swearing....
