Old 01-10-2021, 06:44 PM   #1
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
2021 LT1 1050 miles 2 months old
Have 1050 miles on my 2 month old LT1, car has seen redline 5 times, no oil consumption, engine seems to have broken in well, I did not baby it, but didnt abuse it either. My engine was built sept 17th (day 260) and I assume no valve spring issues.
lt4camaro is offline   Reply With Quote
Old 01-10-2021, 06:49 PM   #2
ThirdGenNut
ThirdGenNut's Avatar
Drives: 2020 LT1
I have missed missed shiftts 3 times in 5k miles. heads are strong like bull!
ThirdGenNut is offline   Reply With Quote
Old 01-10-2021, 07:02 PM   #3
lt4camaro
lt4camaro's Avatar
I have a A10 car, those redlines were during WOT 2-3 shifts in auto mode at about 62-6400RPM and let the car deaccelerate against the engine when lifting after the 2-3 shift, not from missed shifts or holding a gear in manual mode and hitting the fuel shut off rev limiter.
Old 01-10-2021, 07:32 PM   #4
Z28James
Z28James's Avatar
Drives: 2021 Camaro 2SS; 2022 Bolt
I have a 2020 SS with 2k on the clock and so far no issues.....built in the scary month of July 2020.
Z28James is offline   Reply With Quote
Old 01-10-2021, 10:49 PM   #5
Mikey Likes
Drives: 2020 2SS Vert...2019 F-250
Are there specific days where issues were identified? As in scary month of July?
Mikey Likes is offline   Reply With Quote
Old 01-10-2021, 11:41 PM   #6
NotFast
Drives: 2021 LT1
I'd see if the DEA made any big busts around the plant this year
NotFast is offline   Reply With Quote
Old 01-11-2021, 02:35 AM   #7
95 imp
Dumb Ass Deluxe
I was 7.5k on my June 2020 build and I rev the **** outta it...
No issues...
Old 01-11-2021, 05:48 AM   #8
CHASLT1
Drives: 2021 Camaro LT1
Had mine 3 months and at near 900 miles and no probs yet.
CHASLT1 is offline   Reply With Quote
Old 01-11-2021, 07:27 AM   #9
Crushin_LT1
Crushin_LT1's Avatar
Drives: 2021 LT1 6spd
2 months and 2000 or so miles, no issues whatsoever. Great car to drive, very fun.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black
Crushin_LT1 is offline   Reply With Quote
Old 01-11-2021, 07:31 AM   #10
lt4camaro
lt4camaro's Avatar
Are you talking about the build date of the car or the engine? My car was built 11/02, engine was built 9/17. There is a date code sticker on the back of the drivers side cylinder head, cannot see it with out a mirror. If your car was built in July, I would say your engine could be a June built engine which is before the Valve spring issue I think.
Old 01-11-2021, 07:39 AM   #11
lt4camaro
lt4camaro's Avatar
Engines built in July, August and September. Your build month of the car on the door opening decal is just that, The month your car came off the assembly line, not when the engine was built.
Old 01-11-2021, 08:42 AM   #12
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Most of the valve spring failures APPEAR to be early-under 500 miles. A bad heat treat is my diagnosis - but heck I'm an amateur.
If your at 1000 miles I think your fine.
BTW- its all the DI LT engines- 5.3 and 6.2 .....
Old 01-11-2021, 09:10 AM   #13
lt4camaro
lt4camaro's Avatar
No issues...
Your motor was built long before the valve spring issue, probably in May.
Old 01-11-2021, 09:10 AM   #14
lt4camaro
lt4camaro's Avatar
Thats what I am hoping.
