![]() Drives: 2016 Camaro Join Date: Oct 2017
Has anyone tried 295/30ZR20 tires on the 10" wide rims over the factory 285/30ZR20 size.
When looking at the factory Goodyear Eagle F1 Supercar 3 tires the 295's have a half-inch of additional section width, six tenths of an inch tread width, and two tenths of an inch additional diameter. I don't see any issues, but someone who's tried the combination might know better. I'm not one to run spacers.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
No bit of that is going to turn in to performance on the street or track there's no reason to dabble in a 295/30 unless you just like typing "295/30". |
#3 | |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
only disadvantage would be in auto-x, you would have to swing slightly wider through the slalom sections, which will slow your times
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I can tell you there have been people that have run the 305 rear tire on the front SS 1LE wheel. A 295/30R20 will fit on the front 10" wheel, no problem. As far as performance? Eh, I can supply comments of others thoughts (opinions) on potential gains, but it's honestly not going to provide anything more clear than what you can gather right now - which is you will probably lose a bit of steering response and maybe gain a little grip. The 285 GY SC3 already runs a touch on the wide side of a 285...
Honestly, I have been thinking of trying the 295/30 up front, and was going to do it this summer, but my track season was cut a bit and didn't get around to using up my front 285/30 tires to needing replacement... I'm not sure if I will end up trying that out as I feel the 285/30's in the SC3 up front do a pretty good job. In my experience, on an SS 1LE, there is something to be gained to tidying-down the rear a bit over upping tire width on a 10" wheel. Something I'm beginning to find as I push the car more from 9/10ths to my 10/10ths. |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I just installed 295/30/20's on the front of my 1LE. You can see a little bit of tire bulge, but it's not bad at all. I only did it because I got a crazy deal on Bridgestone S007A's.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
On the SC3s, the OEM size is made specifically for the Camaros, I think the other sizes are likely a different compound that will be softer and warm up faster, prolly not last as long. Better for autox, cooler temps, etc. OEM SC3s love the heat, seems very difficult to get them too hot and it takes a while to warm them up.
#7 | |
#8 |
![]() Drives: 16 HBM 2SS Join Date: Apr 2019
I have 295s on the front and they do poke a bit but I kinda like the look.
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I’m running 295s up front for about 1 year now and love it.
#10 |
![]() ![]() ![]() Drives: 2016 SS Convertible Join Date: Sep 2016
I am running 295/35/19 on 10.5” wheels all around.
It’s a very nice setup. I moved from SS sizes not 1LE. But the steering feel and response is very good. Grip is quite good as well. |
#11 |
![]() Drives: 2018 SS 1LE Join Date: Sep 2018
#12 |
Shifts under load
No pics yet. I'm just daily driving it and it's fine. I'm supposed to go to a HPDE at the end of Feb.
#13 |
Shifts under load
Here ya go
#14 |
Those are indeed black and round.
