![]() Drives: 2019 camaro 2ss Join Date: Feb 2020
Anyone running 325s?
What wheel\tire specs are you guys running to fit 325s nicely? just got my car back making 600whp, ordering new wheels\tires in the next few days and need some help with fitment numbers, would love to see examples if anyone has a similar setup! not set on the front specs so give me your input!
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
I'm running 275/35/20 front and 315/30/20 rear on 1LE wheels (10" wide front, 11" rear), which is a near perfect ratio match for the standard 2SS. Depending on what your main goal is, you can go 285/35/20 front and 325/30/20 and retain the match, but then you'll need small spacers.
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Apex has direct fit wheels for the 6th Gen. 11"F 12"R.
I run 305/325 19" with them. https://www.apexraceparts.com/shop-b...aro-wheel.html
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
4S 305/325 ZR3019
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#5 | |
I actually might go with these wheels Do you have pictures? any rubbing issues
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I’m running 295/30/20 front and 325/30/20 rear. Wheels are 20x10 front and 20x11.5 rear.
#7 |
![]() Drives: 2017 1SS 1LE Join Date: Aug 2017
These cars are all the same in the rear - a ZL1 1LE rear wheel runs a 325 stock. Get a wheel that matches that fitment and it'll bolt up.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
#8 |
But the zle is running 11 inch wheels up front which I don’t think I can do on the ss
#9 |
325 isn't going to do any better then a 305 or 315 with the right compound for the job. Put a 305 or 315 555r2 on it if you want better traction.
#10 | |
No spacer required. No rubbing. They are ZLE widths, but the wheel offsets are changed since the DSSV's on the ZLE are thinner. You may want longer studs. Not required since you aren't running a spacer. Apex can sell you the ARP kit when you buy the wheels.
2017 HBM SS 1LE
#11 | |
Ugh. I wouldn't wish a Nitto on my worst enemy. Unless it was DR. Nitto makes a decent streetable DR.
2017 HBM SS 1LE
#12 |
What tires are you running? I’m using ps4s now but was thinking about 888r’s
#13 |
I believe I suggested the 555r2. That is Nittos latest drag radial and it drives as well as a good street tire but with a lot more traction.
#14 |
Do you think I’d be able to fit a 345/30/19 555r2 on a 19x12 apex arc 8 wheel?
