Old 11-13-2020, 10:54 AM   #1
Umbriel
Drives: 2016 Camaro SS
2016 SS Shift to Park message and won't start
Ok so we have been dealing with this issue for about 2 weeks or so now. I drove the car to work one day and when I went to leave it wouldn't start and the dash had the "Action Required: Shift to Park" message.
We have replaced the shifter because that seems to be a common issue and that didn't fix it. Then we replaced the fuse block on the battery and that didn't fix it so we replaced the TCM and still same thing. Traced wires and plugs and found nothing out of the ordinary so we are at a loss. We just towed it to the dealer that acted like they didn't want to touch a modified car.
Anyone have any ideas on this? I have no faith in the dealer repairing a modified car and have a feeling we are going to have to fix it ourselves.
Umbriel is offline   Reply With Quote
Old 11-13-2020, 02:03 PM   #2
ember1205
Hot Camaro
ember1205's Avatar
What if you put the car in neutral? Will it start then? Possibly have to engage the parking brake as well? I think all of my automatic's have been able to start while in neutral in the past, though I've never tried it with a vehicle with push-button start.
It would -seem- as though some sort of sensor is not picking up that the transmission is in park, but I haven't a clue whether that sensor is a physical one that detects the position of the shift lever, something within the transmission, or maybe even both (to detect neutral).
Old 11-13-2020, 02:18 PM   #3
Umbriel
Have not tried that, the car is at the dealer right now but I have no faith in them working on a modded car.
Old 11-13-2020, 02:21 PM   #4
ember1205
Hot Camaro
ember1205's Avatar
What are the mods? I think that would determine where they'll go with it.
Old 11-13-2020, 04:34 PM   #5
Umbriel
Forged 416, twin turbos, secondary port injection, Procharger intake, Circle D converter, DSS chromoly drive shaft, GeForce Outlaw Axles, drag pack.
Sent from my SM-N986U using Tapatalk
Old 11-13-2020, 06:22 PM   #6
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Any chance that a wire underneath the car got pinched or too close to heat and melted? Maybe a bad pin in a connector on the shifter?
Here are a few threads with the same problem. You’ve tried most of the suggestions but maybe they will help you fix yours.
https://www.camaro6.com/forums/showthread.php?t=553306
https://www.camaro6.com/forums/showthread.php?t=556720
https://www.camaro6.com/forums/showthread.php?t=566039
Old 11-13-2020, 07:07 PM   #7
Umbriel
I guess anything is possible with all of the crap we put on this thing. My mechanic said he traced the wires but who knows.
Old 11-15-2020, 11:09 AM   #8
Umbriel
Well the dealership said it is a wiring issue and will be about 6 hours of labor to fix. Not sure exactly yet but I'm betting something rubbed up against something and is exposed now or something melted against the turbo manifolds.
Old 11-15-2020, 11:52 AM   #9
cgdelena
cgdelena's Avatar
Drives: 2019 2SS
I had a similar problem and saw that the defroster light was lit while sitting there trying to figure out what to do... turned it off and everything returned to normal. Has not reoccurred.
https://www.camaro6.com/forums/showt...highlight=park
cgdelena is offline   Reply With Quote
Old 11-15-2020, 02:03 PM   #10
Umbriel
That is odd, we've disconnected the battery so I know it isn't that but that is odd.
Old 11-16-2020, 04:43 PM   #11
Umbriel
Just for the next person to run into this a ground had rattled loose on the back of the driver's side head. The ground is shared by the ECM and TCM and neither had a ground and caused the issue.
