Old 10-28-2020, 10:02 PM   #1
Ummpwr
Drives: Honda S2000
Cam C wheel & tire fitment
Hey Guys, I've been interested in moving from BS to CamC in autox so
1. I can play around with more mods and
2. The pax delta is 0.814 to 0.818 so I feel like with CamC basically being unlimited with 200tw tires that CamC would have the advantage.
Anyway I got some Forgestar f15 wheels from a c7 corvette 18x11+34 w/ 32mm spacers w/315/30/18 front & 18x12 +49w/15mm spacers w/335/30/18 rear with Rival tires.
I have max stock negative camber with factory adjustments front(2.6) rear (1.8)
First autox with the set up is this Saturday
Updated with ramp test. 2 fingers + 2 mm of gap when on my makeshift ramp set up. 3 fingers gap to fender when flat on ground.
Thanks Eric
Ummpwr is offline   Reply With Quote
Old 10-28-2020, 11:21 PM   #2
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
I have max stock negative camber up front
Thanks Eric
OK when you say max stock camber, how much exactly were you able to get out of the fronts???? ON the rears , how much negative camber are you running there??? For track settings without camber plates you would want about -2.4 to -2.6 degrees negative camber (I run -3.6 but I have VORSHLAG camber .plates). ON the rear I would try -2 degrees negative camber. Try intially 30PSI COLD pressure in the tires I cant tell from the pictures but I assume you have extended wheel studs ????
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 10-29-2020, 06:24 AM   #3
Ummpwr
Drives: Honda S2000
Yes the spacers have studs built into them.
Old 10-29-2020, 08:39 AM   #4
AustinTXracer
Drives: 20 SS 1LE
Both front and rear look risky to the fenders. I'd try rolling one tire of each end up a ramp first to see how far up the tire could go and make sure it doesn't reach the fender.
John Hale
multi time solo nats runner up :(
AustinTXracer is offline   Reply With Quote
Old 10-29-2020, 09:24 AM   #5
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
I would think 315/30/18 A052's would be way quicker than the BFG's.
RUQWIKR is offline   Reply With Quote
Old 10-29-2020, 11:32 AM   #6
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Yeah, I was going to say I like his style, but I want to know if he is going to be hitting the fenders. Can definitely go to smaller spacers.
Agreed
Old 10-29-2020, 12:05 PM   #7
Ummpwr
Drives: Honda S2000
I agree, I don't like the "poke" look but because of the offsets being for a c7 corvette I needed all of the spacers. I only have a few mm clearance to the front struts.(I know best would be camber plates)
I will do the ramp idea and make sure I won't hit the fenders.
I would also think the a052 would be faster but they already had the rivals on the wheels. I want to drive a couple hours plus to autox events and I think the rivals will last longer under my conditions
Plus the rivals come in the 335 rear tires where the a052 max out at 315, so maybe some of the extra width can make up for the lack of grip???
Thanks for your feedback
Old 10-29-2020, 12:45 PM   #8
TheRealJA105
Drives: 2013 C6Z06
Please update with pics of the ramp test. I don't think I've ever even seen anyone verify that ZLE front wheels with an 11ET won't hit the SS fenders under full compression. You have a 2ET with more poke but more height clearance with the smaller diameter 315/30/18s.
I'd recommend strut grinding and less spacer, but if it works and clears that's good.
Old 10-29-2020, 12:54 PM   #9
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
The A052's are on the wide side for a 315. They're fine on an 11" but are even better suited on a 11.5 or 12". I get it that the adapter spacers have the studs pressed into them, but, be sure you have enough engagement. Are the spacers 12mm studs like the Vettes use? You should look at how thin of a wall the spacer is at the point the internal nuts go that mount the spacer to your existing studs. Some are very thin, and I personally would not want that for track use.
Old 10-29-2020, 01:38 PM   #10
bpflibsen
Drives: 2009 Pontiac G8
ZLE Front wheels with 305's should be fine. I'm running 19x11 +38 wheels with a 25mm spacer on the front(Effectively +13). For the better part of a season, I ran 2.6* of camber with the strut ground for clearance. It still poked, but I never had an issue of the tire getting into the Fender. One of our sites has some pretty severe bumps aslo. Ummpwr's set up has quite a bit more poke, but like you mentioned the shorter height should help.
bpflibsen is offline   Reply With Quote
Old 10-29-2020, 02:34 PM   #11
Ummpwr
Drives: Honda S2000
Will see if I can get the ramp test tomorrow, my autox is sat so I'll know after the event one way or another 😜
There is a pretty large gap in the fender well with how short the 315/30/18s are.
Down the road I'd like to do camber plates to elimate some of the excessive spacer I'm using.
Good to know about the a052 being wider than advertised.
Old 10-29-2020, 04:09 PM   #12
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
I'll throw in here that I would strongly recommend using longer studs and a plain "pass-through" spacer rather than a thin adapter (especially if the adapter only uses 12mm studs - yikes!). Then you can use whatever thickness spacers you want, and you'll never have to worry about structural integrity.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 10-29-2020, 04:21 PM   #13
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I cut the "nose" off 1" longer ARP studs so they fit the stock setup using closed-end lug nuts while allowing the use of up to 1" spacers as well.
It was easy using a stud-installer and 1/2" impact, don't even have to take the brakes off. You do need one open-end lug nut though.
Old 10-29-2020, 04:27 PM   #14
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
I think this is a pretty decent CAM-C setup, even if I do say so myself-
https://www.camaro6.com/forums/showthread.php?t=582992
I ran that on my 2016 SS (with a different stud/spacer setup) and my 2019 ZL1 1LE with the included spacer. It worked great.
rotis is offline   Reply With Quote
