![]() Drives: 2019 ZL1 1LE Join Date: Sep 2010
SOLD: 19x11 Forgestar CF5V w/RE71R CAM-C Setup (PacNW)
*** SOLD ***
Bump, price dropped to $1,000.
Another bump.
![]() ![]() ![]() ![]() Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
oooooooooooo
#53 F Street
2025 FS National Champion 2025 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 |
![]() Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
Do the wheels have deep enough pockets for the lugs that pass through the spacers? I put extended lugs on my front end and wouldn't want to have them run into the inside of the wheel hub. also are the spacers hubcentric?
The studs installed on the hub pass through the spacer, and they fit into pockets on the backside of the wheel. There is a limit to the depth though, I'm not sure it would fit with longer studs. If you've got *super* long studs you may just be able to knock the studs out of the spacers, it all kinda depends on what struts you are running and how much spacer you need.
