Old 10-14-2020, 12:01 PM   #1
1ssa_camaro
Drives: 2017 Camaro 1ss A8
Biggest tire for front wheels?
Hello guys, just ordered some 305/35/20 nitto nt555R for my stock rear wheels. Others on the forums have said they fit perfectly fine. I’m now debating on which tire size I’ll need for the front wheels. Can I run a 265/35/20? Or a 255/35/20 is just fine? Preferably looking for nitto tires in the front as well thanks
1ssa_camaro is offline   Reply With Quote
Old 10-14-2020, 12:05 PM   #2
sb101985
sb101985's Avatar
Drives: 2017 Camaro 1SS Convertible
I'm running 285/30ZR20's on the front with MRR M228 20x10 wheels. I've made no modifications, and have no rubbing.
sb101985 is offline   Reply With Quote
Old 10-14-2020, 09:08 PM   #3
Yang N’ Bang
17’ Hyper Blue 2SS
Yang N’ Bang's Avatar
Drives: 17’ Camaro 2SS
I’m running a 275/35/20 in the nitto nt555’s up front and 305 rear, no issues with either size rubbing.
Yang N’ Bang is offline   Reply With Quote
Old 10-15-2020, 04:32 PM   #4
enzia35
Drives: '16 Garnet Red 1SS
255/40/20 is a decent size upgrade for the fronts. 305 in the back is not ideal for stock wheel.
'16 Camaro 1SS
'18 Miata GT
Old 10-15-2020, 05:03 PM   #5
wwiiavfan
Drives: 2017 1SS Hyper Blue
265/35 Nitto 555 G2’s fit fine on stock SS fronts. 10k trouble free miles on mine.
wwiiavfan is offline   Reply With Quote
Old 10-15-2020, 05:17 PM   #6
CoeusAscended
Drives: Chevrolet Camaro SS 2018
Just because it fits doesnt mean its fine or will be fine in the long run, running 305s on 9.5" wheels just isnt smart, and is way below the minimum recommended size for that tire width. 10.5" is the minimum for a reason, it'll compromise your sidewall strength otherwise.
CoeusAscended is offline   Reply With Quote
Old 03-26-2025, 08:12 PM   #7
Colin101234
Colin101234's Avatar
Drives: 2017 FIFTY 2SS HCI
I know this is an old thread but I assume it is a 265/35/20. Are you sure it was a 35? That's the same I want to run but dont want to have a rubbing issue and waste $ on tires that won't work.
*STG 1.5 Frankenstein ported/milled heads(.025),
*Custom Cam Motion Cam (224,242[.647/.639])
1 7/8 headers, Ported LT 2 Manifold, Solar Ported 95mm TB, Cold Air Induction CAI, CHE Valve seats, Inconel EX valves, FED/PAC .700 dual springs, VVT Delete, CHE Trunnions, Caddy R Lifters, 3 In Midpipe, NPP Borla atak mufflers, GPI tune.
Colin101234 is offline   Reply With Quote
Old 03-27-2025, 09:54 AM   #8
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
Use this calculator. There's a tab that you can compare tire specs: https://tiresize.com/calculator/
FYI... the 315/30R20 is almost exactly the same diameter as the stock 275/35 tire. Unless you're looking for a taller sidewall, the 315/30 will keep your speedo accurate.
Bad Anvil Garage is offline   Reply With Quote
Old 03-27-2025, 01:20 PM   #9
S.Macias
Monterey County Camaros
S.Macias's Avatar
Drives: 2016 Camaro V6 1LT
I use to run a 275/35R20 front until I stepped up a size to 285/30R20. No issues with either tire. Just make sure to use the correct offset
Instagram: @smaciasracing
S.Macias is online now   Reply With Quote
Old 03-27-2025, 05:02 PM   #10
Colin101234
What offset did you use? I have a 20 offset in front. If I could use that size it would be great without rubbing.
