Old 10-12-2020, 02:10 AM   #1
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
Question Corner Weights
Anybody weigh their Camaro lately? I used my old ProForm wireless scales and got the following corner weights on my 2016 2SS. All weights in pounds. No driver. Full take of E85.
LF 916 RF 1012
LR 754 RR 752
Total: 3,434 lbs.
I'm thinking Chevrolet accounted for the driver and intentionally kept the left-front a little lighter.
Next time I'll get a weight with the driver.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 10-12-2020, 11:52 AM   #2
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
3434?? Wow, ...well, I weighed my at one of the certified CAT truck scales: 3740 with full tank of gas and no driver. 2018 2ss A8 NPP. Wondering where the other 300# went or came from....
Eric10905 is offline   Reply With Quote
Old 10-12-2020, 12:08 PM   #3
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
I find that very interesting, considering my 2018 V6 weighed 3380 lbs (with 1/2 tank of fuel) on a certified cat scale. Every published source, along with multiple personal verifications, show the SS to be anywhere from roughly 3600-3800 lbs to cover the broad spectrum
HCI2000SS is offline   Reply With Quote
Old 10-12-2020, 12:36 PM   #4
Move_Over
Drives: ISO ss 1le
Sounds like your scales need to be calibrated...mine was 3625 with no rear seat and 40lb weight loss in wheels/tires
Move_Over is offline   Reply With Quote
Old 10-12-2020, 03:28 PM   #5
GTO_Gregory
Drives: 2016 Camaro
That's why I posted. I just wasn't sure. So, I contacted ProForm and the gentlemen is sending me calibration instructions. I'll need 500lbs. of sand bags per scale only doing one at a time. Supposedly, it's then accurate to 1/2 of 1%.
I measured myself, which is a quick ballpark measuring method, and it measured me 2.6% over my actual weight.
The scales were zeroed before lowering the car on them.
In any case, I'll try to get what I have working before sinking $800.00 in a new 7K set. Mine are 5K.
Old 10-14-2020, 11:06 AM   #6
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
If don't have the four scales perfectly level to one another, the corner weights are meaningless. The overall weight should still be accurate, though; but like the others I don't believe there is any way your car is that light. So do the calibrations, but don't think about corner weights unless you really have the scales level to one another.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 10-14-2020, 12:21 PM   #7
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
With and without driver. 2019 ZLE M6. Cross weights 49/51.
m3bs is offline   Reply With Quote
Old 10-14-2020, 02:45 PM   #8
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Time traveling to get your car weighed in 1970!?!?!
Old 10-14-2020, 02:58 PM   #9
m3bs
m3bs's Avatar
I was waiting for someone to pick up on that.....
Old 10-14-2020, 06:56 PM   #10
Sorange
Sorange's Avatar
Drives: 2018 ZL1 1LE
my stock 2018 ZLE weighed 3876 with roughly 3/4 tank of gas. No driver in the car.
Sorange is offline   Reply With Quote
Old 10-14-2020, 07:21 PM   #11
ember1205
Hot Camaro
ember1205's Avatar
LF 916 RF 1012
LR 754 RR 752
Total: 3,434 lbs.
Put the engine oil and tranny fluid back in and try again. Oh, and fill the cooling system, too. Let the nitrogen out of the tires and refill with regular air. You'll be all set.
In all seriousness - are you still running the OEM wheels and tires? If you swapped out to something else, that could account for -some- of it.
Also worth blending in here is that the coupes are lighter than the convertibles and the manuals are lighter than the automatics. So, the lightest car is a manual coupe while the heaviest (at just under 4000lbs) is the automatic convertible. Weight distribution should be 54/46
corner, proform, scale, weight
