![]() Drives: 17 Camaro SS Join Date: Nov 2019
Shift Light
I bought a Proform shift light and can't figure out how to wire it. I thought I could get the signal from the #1 coil. I watched a You tube video where someone hooked op a Phastek shift light to the #1 coil harness.
Did not work so now I'm wondering where to get the signal required for the shift light. Any help out there??
Flow Tech axle back, Roto-Fab, Nick Williams 103, AEM Wide Band, Defrost vent pod, billet catch can, BBK long tube headers and NGK LTR6GP, #90198, one step colder, Magnuson 2650, Snow Performance water/methanol injection. (Also tune myself w/HPTuners)
![]() Drives: 2018 1SS M6 Join Date: Feb 2018
those are two different brands. they may wire up differently from one another. did yours not come with instructions?
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Looks like a standard hook up. Black to ground, red to battery or 12V key on, and green wire to one of your coil wires that’s green for your RPM signal.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
I recall the shift light not being straight forward on our cars. Here’s some information from other members.
https://www.camaro6.com/forums/showthread.php?t=505462 https://www.camaro6.com/forums/showthread.php?t=498716
#5 | |
You’re always full of good information. Thanks for sharing.
#7 |
Thanks man just trying to give help back to the GEN6 community. This forum is the best place for info, DIY, and advice from so many members here.
#8 |
Tried to use the connector from the #1 cylinder coil but didn't work. I'm thinking maybe the crank sensor or the PCM. Not sure so I'm lost for now.
#9 | |
“ Just think of the things you can easily accomplish with our GMR Pickup! This little device simply attaches, with no splicing or cutting, to a current carrying wire and turns that information into a 12 volt rpm signal. This signal can be used to activate a shift light, rpm activation switch or a tachometer. One example is to connect the GMR, which stands for Giant Magnetoresistive, to a diesel injector current wire.”
#10 |
![]() Drives: 2018 Camaro ZL1 Convertible, M6 Join Date: Feb 2018
Does the 8918 work for our cars?
Has anyone used the MSD 8918 (GMR pickup) to drive a shift light? I tried on al 4 wires on one coil and no go, so I am trying the MSD 8913 now.
Thanks in advance! |
#11 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
I just got the Holley Sniper light. Plugs into the OBD2 port. Then program and done.
Comes in different color lights and body colors.https://www.summitracing.com/parts/s...+5d9b7742bfddc
#12 |
Thanks. My OBD2 port is occupied by my P3 gauge most of the time and HP Tuners the rest of the time. Splitters don’t work, they freak out the computer and it throws all kinds of errors in the dash cluster.
