Old 09-19-2020, 07:44 PM   #1
Ants.ZL1
Drives: 2020 ZL1 1LE Shock 1968 Pontiac GTO
2020 ZL1 1LE A10 WEIGHT
Put the car on some scales today as well, always good to know the weight!
First is the car with me in it and about 3/4 tank of fuel second is just the car.
Ant
Ants.ZL1 is offline   Reply With Quote
Old 09-19-2020, 08:41 PM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
3891 isn't bad at all with 3/4 tank of gas. I'm impressed.
Old 09-19-2020, 09:47 PM   #3
Ants.ZL1
I had a few things in the car too, left my race helmet and fire jacket too. Not that they are too heavy but do show what it is in race trim.
Old 09-19-2020, 10:13 PM   #4
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Sounds about right. I have an Manual 1LE. This is in kg as I’m in Canada. But 3835 lbs.
Old 09-19-2020, 10:48 PM   #5
Z OH 6
Nice, I'm going to see what I can do to trim up to 100lbs off my ZL1. I've got a Cox Racing lithium battery that weighs 9lbs, that's a good start to remove 35lbs or more right away. Then I'm going to look into some lighter forged wheels. I've got a set of Kooks headers and green cats coming, I would think those will be lighter than the stock manifolds and certainly doing away with one set of cats should save some weight. Then I've got an AWE exhaust coming, I'm hoping it will be a few lbs lighter as well.
Old 09-20-2020, 07:45 AM   #6
Ants.ZL1
Sounds like a good start, be interesting to see how much it saves. Everything i pull a wheel off im amazed at how light the factory ones feel considering how big the tires are, but I have not weighted them. I wonder what you will save on them.
Ant
Old 01-27-2022, 01:31 PM   #7
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Just weighed a 2022 M6 ZL1 1LE (PDR, full tank of gas, all other stock): 3830# with 54.5% up front, 49.4% on left side. Just FYI.
RUQWIKR is offline   Reply With Quote
Old 01-27-2022, 01:40 PM   #8
zxspeedspec
Drives: Faster than yours
Windshield wiper arms and motor are good for about 10-12 pounds. Windshield washer fluid reservoir another 6-8 pounds. Rear seat delete is 30-ish pounds.
zxspeedspec is offline   Reply With Quote
Old 01-27-2022, 01:50 PM   #9
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
Not bad what have you done to lose some weight or is that factory?
Old 01-27-2022, 02:11 PM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
I believe mine with 2 gal. weighs 3725 with pass. seat., at the strip with Mickey's / F14 it weighs less than 3700
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 01-27-2022, 02:47 PM   #11
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Rear seat base on ZL1 1LE (with out the regular latch mechanism plus less dense foam than regular ZL1 and SS) was 11# and the seat back was 13.4#. I think my SS 1LE were about 31# for both.
Old 01-27-2022, 03:20 PM   #12
zxspeedspec
If you include the seat belt brackets and seat belt itself you'll get ~30# on the ZLE. I've weighed mine when I removed them.
