![]() Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
Removing Catch Can
Unfortunately, I believe my blower has an issue. There's a rattling noise present on the passenger side of the supercharger. I'm going to bring it to a dealer, but I have to remove the catch can. My guess is that they may want to replace the blower (depending on dealer). From my understanding, the bolts from the supercharger to the head have to be replaced each time you take them out. Is there any way that the dealer would find out about this or the process in general? Also, should I put the stock intake back on?
Thanks |
#2 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#3 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
![]() Drives: 2023 SS 1LE Join Date: Mar 2020
These bolts are TTY bolts and a one time use only item. I know, I know... some guys gonna say he used them 100 times over without an issue... problem is, they stretch upon initial use to improve clamping force and once stretched they lose this clamping strength when retightened and will break without warning. Just not worth the hassle and potential broken bolt fiasco that will follow.
Also, if it’s a warranty claim, I would put the stock intake back on also.. make it as close to stock as possible to avoid A denied claim. Not sure how well you know your local dealerships service department manager. It may make a difference. |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Agree and a simple check.
![]() Drives: 2019 Camaro ZL1 1LE A10 Join Date: Jul 2020
Hopefully the tune has no modifications, thats the first thing they look for
#7 |
I bought new bolts and a brake booster line. I want to make sure everything looks factory. Does my brake booster line look like it’s routed correctly in the first picture? Also, there’s a clip on the MAF wire. Where does this clip attach to? Any tips on how to remove the PCV Diverter? I appreciate the help!
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
1- Brake booster hose looks correct.
2- That clip clips to the OEM air intake. There is a plastic tab between where the Mass Airflow Sensor mounts to the OEM intake and the "box" where the air filter element is. 3- As far as the PCV Diverter, you're gonna have to lift the supercharger (you only need about 3-4 inches of lift). It sounds complicated but it's not, remove the supercharger belt and unscrew the bolts (you're gonna replace them anyway). Use a small wooden block to support the supercharger while you get in there with some needle nose pliers and unscrew that PCV Diverter. Then put the stock one back on there. I used a big Allen key to unscrew the OEM Diverter. Good luck with your claim. I hate when cars start making weird noises.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#9 | |
#10 |
I just finished everything back to stock. Is there any need to disconnect the battery? I’ve heard of some people getting a check engine light after changing their air intake. I didn’t get a check engine light when I installed my roto-fab the first time
#11 |
I haven't heard of the need to disconnect the battery when changing air intakes.
With that being said, it doesn't hurt to do so. Leave the battery disconnected over night. DON'T FORGET TO LEAVE YOUR TRUNK OPEN !!!!!!!!!!!!!!!!!!!!
#12 | |
Rattle? Or Chirp?
Good luck with your appointment, hope it's an easy repair
17' Nightfall Metallic Gray ZL1 / Stock-So Far / M6 / Alcantara everything / CF Insert / PDR / NAV
Most important part Britex multi-point car seat for little man & baby girl. Starting em young. "Go Fast Daddy" |
#13 | |
Sounds like plastic rattling. I spoke to a few people and was told that it’s the coupler inside the blower. Unfortunately, a lot of dealers will say the sound is normal even though it’s not. Hopefully, the dealer I bring it to will agree with me |
#14 | |
![]() ![]() ![]() ![]() Drives: 19 Z06 Join Date: Nov 2011
I agree with you that the OP should put the stock intake back in, and hopefully the car is not tuned.
Gone but not forgotten:
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert 2013 ZL1 M6 2014 Zl1 M6 2014 GT500 2016 Challenger Hellcat M6 www.youtube.com/c/garageking |
