Old 08-18-2020, 04:42 PM   #1
ht600
ht600's Avatar
Drives: 2019 Camaro ZL1
LT4 SC Coolant Filler Adapter Tool
I just ordered the Dedicated Motorsports LT4 SC Coolant Filler Adapter Tool to try and bleed the supercharger intercooling system.
This is what I was going to try.
- lift the front of the car with my ramps
- install the adapter tool with bottle and Dex-cool 50/50
- turn on ignition to run to circulate or to start the engine (not sure which one to do)
- let system burp or air bubbles released
- remove adapter tool
Does this sound right?
P.S. this is just a preemptive thing I'm trying not sure if I have an issue.
ht600 is offline   Reply With Quote
Old 08-18-2020, 05:52 PM   #2
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
I use a cut down water bottle and electrical tape I hit the valve every so often while engine is running to bleed
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 08-18-2020, 05:59 PM   #3
ht600
ht600's Avatar
I think the adapter pushes the valve open for you. And the bottle threads in.
Old 08-18-2020, 08:41 PM   #4
Chris357
Chris357's Avatar
Drives: 2018 ZL1 Garnet Red A10
So my only question about that is how do you prevent spilling the extra coolant all over the engine when you unscrew adapter from the fill port?
I guess you just pour little bits in there until full and then remove excess with turkey baster or soak up with paper towels???
2018 ZL1 Red Hot A10 (SOLD 1/21)
2001 Corvette Z06 Quicksilver Heads/Cam/Longtubes 443rwhp (SOLD 5/23)
2018 ZL1 Garnet Red A10 (SOLD 4/25)
2003 Corvette Z06 Torch Red bone stock 60k mi
Chris357 is offline   Reply With Quote
Old 08-18-2020, 09:04 PM   #5
ht600
ht600's Avatar
That is what I was thinking. Don't put too much in the bottle. And I have this to remove extra fluid.
Old 08-19-2020, 06:20 AM   #6
Chris357
Chris357's Avatar
Good idea.
Old 08-19-2020, 06:25 AM   #7
gtfoxy
Drives: '21 Wild Cherry ZL1
Is this a general maintenance kind of thing or only after repairs where the coolant system has been opened up?
Old 08-19-2020, 07:08 AM   #8
ht600
ht600's Avatar
Yes to the above and to remove possible air pockets in the system that may degrade performance.
Old 08-19-2020, 08:12 AM   #9
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Dollar store turkey baster works too.
Old 08-19-2020, 09:53 AM   #10
PROMETHEUS
PROMETHEUS's Avatar
Or just get an aftermarket SC reservoir.....makes life so much simpler!
Old 08-19-2020, 10:06 AM   #11
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
ht600, I saw this item in a post the other day and ordered one yesterday. It's cheap and should be easy to use. I plan to use a Mity-vac to empty the bottle when done.
Old 08-19-2020, 10:07 AM   #12
ht600
ht600's Avatar
Cheap is right!
Old 08-19-2020, 12:27 PM   #13
TBZ06
Drives: ZL1 1LE
Other Options
I came over recently from the Corvette group. I purchased my car (ZL1 1LE) about two weeks ago. I have seen several post on removing the air from the coolant systems on these cars. This was an issue on the C5 Z06 I had, so I purchased a tool similar to this one :
https://www.summitracing.com/parts/oes-24444
It seemed to work well and resolved the issues on the Vette. It’s also the process used on many new vehicles by the dealerships.
This might be a good option on these cars as well.
TBZ06 is offline   Reply With Quote
Old 08-19-2020, 03:50 PM   #14
DFW_Muscle
Drives: 2018 Chevrolet Camaro ZL1
That will not work.
It's not a matter of simply getting a small enough tube in the port to fill. There is a checkvalve that needs to be depressed. Guys that use the upside down bottle with a hose use a thin screwdriver to depress the valve. Your suction gun won't provide a way to depress the valve.
Buy the DMS tool, or buy an aftermarket expansion tank. Or, buy an expansion tank and replumb the system like I did (DMS also makes adapters to convert the male push fittings on the blower to -12an fittings).
DFW_Muscle is offline   Reply With Quote
