Old 08-15-2020, 10:41 AM   #1
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1 1LE
Nav SD Card - GM cost cutting
So I was messing around with trying to get all my music onto an SD card and then installing it in the card slot in the console. I couldn't work out why I was having so much trouble inserting the card. Got in there with a light, and to my surprise I found a card already in there! I removed it, and found that the maps for the Nav system were kept on there.
I was hoping that this was just left in there at the factory for a source to upload to the Nav system. But as it turns out, if you remove the card the Nav does not work!
So now I have to make a decision - Nav or music. I can't believe GM did this. Should have provided a 2nd slot somewhere. Bad design in my opinion - more cost cutting I guess.
I guess I could use a USB drive, but capacity for USB is limited to 16GB, where the SD will support 32GB - frustrating.
Did anyone else realize this was the situation?
Crushed 1LE is offline   Reply With Quote
Old 08-15-2020, 10:47 AM   #2
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
Before I comment on the posted issue: Has the card slot been moved from under the dash in the pre-'19 cars to the console in the '19+ cars?
With my '17, the SD card is only to support the video system. My NAV works regardless of whether or not there is a card in the SD card slot.
Rlhay2 is offline   Reply With Quote
Old 08-15-2020, 10:50 AM   #3
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
I don't know where you learned that a USB drive is only 16 gig. I have a 128 gig USB in my Camaro.
Rayvan is offline   Reply With Quote
Old 08-15-2020, 11:18 AM   #4
Hell Raiser
To fast is not enough
Hell Raiser's Avatar
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo
I have a 2019ZL1 and I don't have a SD slot in the console just for PDR under the dash next to hood opener My USB is in console which will use any gig
Hell Raiser is offline   Reply With Quote
Old 08-15-2020, 11:22 AM   #5
impulse
impulse's Avatar
Drives: Big Dually ... RIP ZL1
Just sell it too me! Lol
Imagine impulsively buying a Summit ZL1.
impulse is offline   Reply With Quote
Old 08-15-2020, 12:23 PM   #6
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
I have a $70 Sandisk 512 GB USB and they make 1 TB
SFV1LE is offline   Reply With Quote
Old 08-15-2020, 01:59 PM   #7
Vigilante375
Drives: 2018 Camaro ZL1
I will never get a useless navigation system in a car again. You can use Google maps, for free, and it is constantly updated or spend $50 or so and get a Garmin with free lifetime map updates.
By the way.... why don't you use your phone for music? Make a playlist and let it play.
Old 08-15-2020, 05:14 PM   #8
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
My purpose for having nav is for when out of cell coverage. No cell coverage = no Google maps u less you pre-downloaded certain routes, etc.
The nav chip slot in my 2019 1LE is in the center console.
ohsmily is offline   Reply With Quote
Old 08-15-2020, 08:57 PM   #9
Crushed 1LE
Thanks for the support. I was getting hammered there for a bit.
2 SD card slots. One under the dash for the PDR. One in the console - apparently for the Nav files.
As far as connecting my phone for audio, I am in a unique position I guess. My phone is used for work and has a ton of security crap in it. It will not allow me to load a SD card for the risk of me transferring sensitive information.
Old 08-15-2020, 09:00 PM   #10
Crushed 1LE
Ive tried a 64, 128 and a 256. Doesn't seem to detect it. Maybe I'll try a re-format.
Old 08-15-2020, 10:34 PM   #11
ohsmily
Forget the SD card. Just use bluetooth or android auto or apple car play to cast from your phone to the car. Why won't that work?
Old 08-15-2020, 11:17 PM   #12
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
The issue here is that you have to format the USB to FAT32. Usually with Windows, it will only format USB sticks below 32GB to FAT32. Anything above that will give you the exFAT format instead.
There are software that can format a USB stick/SD card above 32GB to FAT32 format. I have a software called Minitool Partition Wizard that did it to the 64GB SD card I have for the PDR. Plenty of other options exist.
Other than the signal issues mentioned before, the HUD integration is another plus for the factory system. No need to take your eyes off the road. Can't do it with Google Maps, and it's nice that I don't have to connect my phone every time I drive with the wire getting in the way(especially with a stick shift).
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 08-15-2020, 11:37 PM   #13
chris227
chris227's Avatar
There is a thread on here somewhere which has the part # for a USB/SD module that will fit our cars. It replaces the dual USB module in the console. I will see if I can find it. I bought it for my 2016, but haven't even thought about getting one for my 19 yet. Its like $25.
Old 08-16-2020, 09:27 AM   #14
Crushed 1LE
So are you saying that vehicles without Nav do not come with a SD card slot in the console?
