Old 08-11-2020, 09:07 PM   #1
Rickdickulous504
Drives: 2018 Camaro ZL1 A10
Catch Can on 800-1000HP
Looking for advise from you guys in the high HP range. What Catch Can/Cans are y’all using with your set up. I am a 416 stroker ,ported blower , 9.1 lower pulley and 2.30 upper pulley, 2’’ headers intake BTR stage 3 cam, 103 TB. Any help is appreciated thanks
Rickdickulous504 is offline   Reply With Quote
Old 08-11-2020, 09:55 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Mighty Mouse Wild with -12AN hose setup here, supposedly good for 1200HP. Nice build quality too.
Old 08-11-2020, 11:40 PM   #3
newchevyman
Drives: 2017 Camero ZL1
Just curious, what's the reason to run a stock blower on a 416?
2017 ZL1 A10
Dyno/Quarter Mile/Dragy
9.71@141.2 MPH so far.
2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold.
newchevyman is offline   Reply With Quote
Old 08-12-2020, 10:05 AM   #4
Rickdickulous504
Building on a budget. Had cracked piston skirt so instead of rebuilding it i had it bored and stroked. Ill eventually get a new blower but i already had mine ported so I’m working with what i have.
Old 08-12-2020, 11:19 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Elite Engineering Dual Port (new version) here. I haven't had it on the car for but maybe a couple hundred miles, but was happy with the kit. I had to make a mount because I wanted it in front of the engine (just to the passenger's side of the blower pulley), but so-far-so-good. I haven't checked to see what it has yet caught, but I have an oil change due, and will check then. I expect I'll have some mist residue, but a lot of that 200-miles was a lot of WOT, so we'll see. There was enough hose to route it the way I wanted to. The only little tangle I found was it took a little extra effort/time to find the correct "T" (a brass "T" and adapter from Amazon to get it to work) for the intake elbow for the OEM-line and the second vent connection for the catch can. It was worth the energy to do it, as I'm completely happy with it now.
'20 ZL1 Black "Fury"
Old 08-12-2020, 01:55 PM   #6
20Bluezl1
Is that the Elite E2-X can ? Or the ultra ?
Old 08-12-2020, 02:52 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
http://www.eliteengineeringusa.com/e2-catch-can/
That's what's in the picture I attached. I don't see an Ultra, but I am pretty slow, ha.
Old 08-12-2020, 03:24 PM   #8
20Bluezl1
Ok so I believe you have the older E2 catch can which it was updated to the E2-X not sure whats the difference. The E2-X also comes in a ultra which is bigger so you hqve more air flow and volume to collect.
http://www.eliteengineeringusa.com/e2-x-catch-cans/
Old 08-13-2020, 08:41 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I've assumed I had the newer design as the website said "NEW" but I don't really know. Regardless - I imagine the design you're talking about is at least as good. These are not empty-Chinesium metal boxes with tubes running into them (I've had those, too, in the past...), so I'm sure it's six-of-one.
A lot of people swear by the MM-cans because of the venting features. I'm not sure what I make of that, but it seems that if you start with something that breathes well, and traps oil-laden vapor, then you're on the right track. I'm running about 14-15-psi, so anything that will help capture more junk is okay in my book
Old 08-13-2020, 10:44 AM   #10
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Elite has a front mount bracket now, they sent me one for free a couple of months ago
Elite proves their can works, as well as video proof from members on this forum. I have yet to see any proof the MM comes close in performance
ZX-10R is offline   Reply With Quote
Old 08-13-2020, 12:02 PM   #11
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
I believe a catch can is an excellent mod. I have the elite on my mildly modified engine. Every oil change at 3000 miles is also when I empty my catch can. I find 2 or 3 table spoons of oil every time. On a DI engine especially, its good to know the CC is doing its job.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 08-13-2020, 12:17 PM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I didn't get that bracket, and I wasn't sure I was supposed to. Fortunately, I was able to fab' something up. Maybe I should hit them up. I received a bracket, but it seemed like it was for the strut tower...
Precisely why I followed suit, too.
Old 08-13-2020, 12:20 PM   #13
Choda
Drives: Turbo 6.2
I have a huge custom aluminum tank/catch can with -12 from each valve cover and 3/8 from the valley cover. My tuner said let these babies breathe. I do need to baffle the inside because after some autocross or heavy braking the vapors fill the breather and eventually drip a small amount of oil onto the top of the catch can.
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 08-13-2020, 02:32 PM   #14
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
radz28
Good to hear all is well. And yes, the Ultra E2-X is what is needed when over 12-14#. Your system is fine.
For others wondering, we can go over the list of features, function, and more but easiest is to focus on these few:
The E2, E2000 and E2-X series all can be used for a GDI engine. For forced induction to 10-12# the E2-X, and above 12# the Ultra is really the best design to deal with the challenges. Email direct for ANY questions before ordering so we match the right system and options for the build:
Tech@EliteEngineeringUSA.com and our Engineering and support team will assist and answer any questions. We really want ALL to understand whats involved instead of just "Buy it because we say" Or "So and so has one so I am buying one".
So, here are the main differences:
Our dual valve systems provide FULL time evacuation suction on the crankcase. Only evacuating part time and then allowing pressure to build and vent is never good for any internal combustion engine. That is technology that has NOT been used since the mid 1960's except by those making assumptions and not understanding the critical functions of pulling full time suction on the crankcase so pressure can't build to begin with.
Effectiveness. Our E2-X series holds a US patent and is the most effective on the market period trapping on average 95%. This is no idle boast, it has been demonstrated and proven time and time again. But we still openly challenge ANY other design to a head to head test as we have shared on a regular basis. Take ANY other can and install it on your engine. Then from the other cans outlet, install OUR E2-X can. So we are only getting the vapors that have already passed through the other can first and it has done its best job at separating the substances (water/acids/oil/raw fuel/abrasive soot/ash/carbon) you do NOT want ingested. Starting with both cans clean and oil free, drive as you normally would so driving style is as close to the same throughout the test. 1000 miles minimum, 2000 miles is even more accurate. Then drain each and document what each caught. You will see we trap as much or MORE than the first can no matter who's design it is. This shows how ineffective 99% of all can designs are and do little to benefit the engine. Now clean both and swap so ours is first, and the other design second. Run the same miles and do your best to drive the same way for fairness and accuracy, and drain and see only drops get past ours. That should be all the proof anyone could want, but we provide many more benefits as well.
How it effects the engine oil and wear is also a big deal, and the only way to verify this is through oil analysis: Here is an example of a GDI engine making OVER 20# of boost (so it is subject to far more contamination than a non FI engine) with over 13,000 miles on the oil. As our systems provide full time evacuation (crankcase suction), we are constantly flushing and removing these before they have a chance to settle and mix with your oil. So greatly reducing wear and extending engine life. And it does not matter WHAT make of GDI engine you have, ALL suffer from the issues.
Read the lab techs comments. This is oil condition generally seen at 5k on a GDI engine, and this field tester is over 13,000 miles. NO other can design advertised here can accomplish this, but as we always urge, test for your self and see.
The E2-X Ultra system is good for 1,000 hp and more also.
Questions? Please ask and unlike ALL other designs/companies we are a company built and staffed by actual Engineers and constantly work with industry leaders with testing and R&D. And we share that data and information so members can learn and understand the why and how proper crankcase evacuation works and is critical.
Cheers!!
Elite Engineering is offline   Reply With Quote
