Old 08-09-2020, 04:52 PM   #1
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
Installed JLT Oil Separator
Yesterday evening I installed the JLT 3.0 Oil Separator. A little more work due to the strut tower brace, but, it fits just fine. The separator is hardly noticable once the strut tower brace is back in place.
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 08-09-2020, 06:02 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
Looks great and blends in nicely! Nice job.
Old 08-10-2020, 09:21 AM   #3
bjbonentte
Drives: 2019 Chevrolet Camaro
I like my JLT unit. I am able to unscrew the bottom dump it out and get back to driving. Just make sure you don't over tighten the canister. First time I took it off it was a bitch to get off.
bjbonentte is offline   Reply With Quote
Old 08-10-2020, 10:51 AM   #4
KLG
KLG's Avatar
For sure.
I had an early design JLT oil separator set-up on my GT500 years ago (two separators). I kept the cannister threads lubed with a little anti-seeze and would put a little oil on the o-ring too.
I've done the same with the separator on the Camaro.
Old 08-10-2020, 12:06 PM   #5
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
Easy peazy, one of my first mods, and strut brace fits no problem
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake
OB0001 is offline   Reply With Quote
Old 08-11-2020, 08:07 PM   #6
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
I have the same style from phastek, I empty at every oil change, its normally half full
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
Joey Soul is offline   Reply With Quote
Old 08-16-2020, 12:26 PM   #7
blk 2013
blk 2013's Avatar
Drives: 2017 SS 6sp
do you get much oil in it
blk 2013 is offline   Reply With Quote
Old 08-16-2020, 03:33 PM   #8
KLG
KLG's Avatar
I haven't checked but I have only driven maybe 150 miles.
With an NA engine, I don't expect much especially since I drive kind of easy.
Old 09-05-2020, 01:01 AM   #9
KLG
KLG's Avatar
Oil collected after about 375 miles, maybe a teaspoonful.
