Old 07-31-2020, 11:48 PM   #1
Living_Quiet
Drives: 2010
Dealer damaged fender when lifting improperly. Best fix?
Got an oil change this morning (yeah yeah I know... but. they offer a lifetime powertrain warranty if you use them for all regular oil changes)
Anyways when they lifted it they didn't put the arms out properly, so the driver's side fender is mis aligned with the door. Luckily the panel didn't buckle and the door doesn't catch on it but it's still noticeable.
So I took it around to a couple body shops and I've gotten conflicted info on the best way to fix it so I wanted your guys input:
Option A: I was told there are two bolts behind the panel. They need to get behind there and tighten them to re-align the panel.
Option B: Use a PDR type tool to push the fender back into alignment with the door.
I'm also concerned if there might be damage behind the panel from however all that weight was misplaced? Thoughts? Thanks
This last picture is a reference, showing the perfect alignment before the dealer damaged it.
Living_Quiet is offline   Reply With Quote
Old 07-31-2020, 11:53 PM   #2
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
Why not have the dealer fix it since they caused the damage
HCI2000SS is offline   Reply With Quote
Old 08-01-2020, 12:32 AM   #3
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
HC12000SS is absolutely right. Have them fix it since they caused said damage.
STYLO LT1 is offline   Reply With Quote
Old 08-01-2020, 12:34 AM   #4
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
i think this type of damage is corrected by un-bending the bottom of the panel where the lift pressed up against the fender back to where it should be, but i guess it depends on how much it bent.
just make the dealer fix it. This has been happening to people since 2016. It's only slightly more common than not putting enough oil in the v8's during a simple oil change.
Old 08-01-2020, 12:35 AM   #5
Living_Quiet
Drives: 2010
They're paying for it, but they don't have their own body shop. I took it to the shop they use, but obviously shopped around at one of my choice.
I received conflicting info on how they would fix it, so I'm curious what others think.
I will post pics tomorrow.
Old 08-01-2020, 10:40 AM   #6
RWT
RWT's Avatar
Drives: 2020 Camaro RS
I find the term misaligned to be interesting. I am trying to conceive how a force can be placed on it to misalign it without some damage occurring. Wouldn't something need to bend or buckle? Did it just shift at the mounting points?
It seems something would have to push/pull the fender to make it misaligned. Additionally, it seems the only way it could involve the fender and fender alone would be if they placed the lift directly on the fender. Otherwise, the fender would be moved by the malformation of whatever structure the lift was placed on. For example, if they buckled/damaged the aluminum structure the fender attaches to, it would move the fender but also damage the structure.
Fenders don't just move on their own. If I had to guess, and I am just guessing, I'd say there is some damage other than just the fender alignment.
Assuming there is other damage under the car, can the fender be realigned without actually fixing that damage, maybe so (working with limited info here). Should it be realigned without actually fixing the damage, no. But at this point the body shop is working for the dealership not you. So their client's best interest is important here, not yours.
I would get a good look under there and see what bent/buckled to move the fender and make sure it gets fixed too.
JMHO
No expertise implied or expressed
RWT
2020 Camaro RS, V6, 6MT, Satin Steel
2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray
2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic
RWT is offline   Reply With Quote
Old 08-01-2020, 11:29 AM   #7
The Blackheart
Drives: 2019 SS/1LE Riverside Blue, Z/28s
Can you post photos of the damage?
The Blackheart is offline   Reply With Quote
Old 08-01-2020, 11:36 AM   #8
+1, no proper advice can be given without seeing the actual damage
Old 08-01-2020, 01:50 PM   #9
Living_Quiet
Drives: 2010
I added pictures to the original post.
Old 08-01-2020, 02:56 PM   #10
Herewego
Herewego's Avatar
Drives: 2018 2SS
I can't believe that dealers are still doing this after 5 years. I fought with the general manager over this when they did it to mine. They tried to blame it on body flex, blah, blah, blah...until I showed him my photo of the mark under the fender where the tech placed the lift. They had their body shop repair it in about an hour or so. The fender is likely collapsed a bit from the lift and they simply massaged it back into shape. I think he said that they also did a small adjust on the door. It came out about 90% and you don't ever notice it unless you look for it. Unless rocker is crushed, they can probably just re-shape it back to normal (or near normal)
Herewego is offline   Reply With Quote
Old 08-01-2020, 03:13 PM   #11
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
Looking at the pictures it just looks like they need to realign the front fenders. Also check your rocket panels and make sure there are no dents/cracks... I’d also recommend you pick up a set of Jack/lift pads for your car to make sure the dealers don’t damage your car.
Sorry this happened to you. It’s happened to me twice and neither times the dealer would take the blame for any damages.
Azerlazer26 is offline   Reply With Quote
Old 08-01-2020, 03:14 PM   #12
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
Looks to me like they didn't even use the lifting pad. By missing that the pressure applied to the underside rom the weight actually bent it up. When it was pushed up it forced the bottom of the fender out. I you look on the underside of the car right by the fender I bet you see more damage.
Modernmusclecar is offline   Reply With Quote
Old 08-01-2020, 03:25 PM   #13
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
A common occurrence still happening and yes it’s mild damage but needs to be fixed. Since the dealership is paying to have it repaired take it to a highly rated body shop that has good reviews and have them fix it. A couple of years ago that is what happened to my 2016 when having new tires put on and the Tire Dealer that installed the tires fixed it by one of the Techs that worked in the shop. I was told that he had worked in a body shop years earlier and the tire shop had to repair some Corvettes they lifted wrong in addition to some Camaros. Everything turned out good with my 2016 SS so the damage can be repaired but it’s carelessness by techs that cause these issues.
Old 08-01-2020, 04:02 PM   #14
Allez
Allez's Avatar
It's amazing this is still happening, the car having been out for 4 1/2 years.
Allez is offline   Reply With Quote
