![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
Modified ZL1 low pressure pump
I see a lot of boost a pumps, add on low side pump kits, and the Fore type replacement but I'm wondering if anyone replaces the existing in tank low side pump in the factory bucket with an upgraded unit.
Not a popular thing since you'd need to drop the tank or cut the sheetmetal paneling to get to the pump.
Sent from my SM-N975U1 using Tapatalk |
I believe several including Lingenfelter offer drop in twin and even triple pumps. Ain't cheap.
https://www.crawford-racing.com/prod...le-fuel-system https://www.camaro6.com/forums/showthread.php?t=544327
Moderator
I’m running a DW400 in tank pump using the factory ZL1 bucket. Seems to work fine so far, no voltage booster needed. It was made by DixieZL1 on this board. Supposedly outflows the ZL1 pump by 30% at 70 psi. We will find out soon, I’m heading to the dyno this Monday (7/27) to sort out my new combo...
Edit for future readers (9/5/20): I ended up needing to add the JMS voltage booster to get this pumps potential to show up.
#5 | |
Thanks Josh! This is exactly what I was hoping to see. Please keep us updated and good luck! BTW, did you need to upgrade the wiring harness or add a backflow valve? I saw DW mentions the possible need for a valve on their DW 400 page. Last edited by GreenZLE; 07-22-2020 at 10:39 PM. |
#6 | |
Moderator
#7 | |
Dyno Show Queen LOL
When people buy the LPE injectors and there Big Bore pump this and the high flow Ck valve with bigger lines is the key to get 900 plus on all E with there setup. people screw up and try with a SMG or DSX aux and it's not gonna happen.. it will actually do 80 psi under load.
#8 | ||
I would agree with you and I intend to run a completely separate system from tank and use all AN fittings, T, and hoses right to the HPFP. I will be actually pretty easy to modify the DSX setup to do this (I've been just lazy). To my mind the DSX setup is reasonable for 850 engine on E and street and / or drag racing use. The only caveat on my setup is I also run the LT4 in-tank. Above 850 engine, I'll leave that to the guys who know, I just know the factory fuel lines suck at the tank and just before the HPFP, also the LT1 high pressure line sucks and one should get an LT4 one with less bends. The first two issues CAN'T be fixed by a better or more pumps in the tank (nor voltage booster).
