Old 12-14-2018, 06:45 PM   #1
toohighpsi
Drives: 2015 C7 Z06 M7
Lingenfelter Dual In-Tank Pump System.
Lingenfelter Dual In-Tank fuel system rocks!
Previously we were running an in-tank ZL1 pump and Inline Weldon 1100 with -8 lines to feed the LT4 HP pump, 8 - LT4 injectors, and 8 - 600cc/min port injectors (production hellcat). We run both DI and port injection to meet the fueling demands of this Livernois Performance built 416
With the previous fuel system we were struggling to maintain 40psi on the low side and keep A/F ratio safe at the end of a run.
We needed something better and I saw Lingenfelter's advertisement for the dual in tank system - phone call, credit card, and a couple days later we had a new option.
Name:  Photo Dec 11, 5 20 28 PM.jpg
The Lingenfelter system has 2 - 450 l/hr pumps in the stock basket. It requires some additional wiring, but otherwise was pretty easy to install.
Now with the dual in-tank pump system the low side fuel pressure remained at 75psi+ for the pull (which was dyno logged) but from the HP tuner log you can see that we we able to hold HP fuel pressure and a 12.0 A/F ratio across the pull to 7K RPM with up to 252 kPa of manifold pressure (22psi boost).
Name:  FP Screen Shot.jpg
So - after many months of headaches - the car is finally staying WOT with the TH400 transmission and we have enough fuel to feel safe. Initially I think the converter might be too loose but won't know for sure until we get to the track. Hopefully next week we can get out for a couple of shakedown passes with the new combination (my favorite part).
Old 12-14-2018, 06:47 PM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I was wondering what happened...glad it's sorted out now. Look forward to seeing the results.
Old 12-14-2018, 08:03 PM   #3
GT-ER
Drives: 2018 Camaro ZL1
Hmmm...where can I get this? I don't see it on their site.
GT-ER is offline   Reply With Quote
Old 12-14-2018, 09:08 PM   #4
laynlo15
Drives: 2022 Lt1 A10
I think its just been released and may not be on the site yet. That's gotta be 1150+rwhp at 22 lbs of boost.
Old 12-14-2018, 09:19 PM   #5
GT-ER
How much does this pump cost?
Old 12-14-2018, 10:08 PM   #6
newchevyman
Drives: 2017 Camero ZL1
Also interested in cost. Probably not cheap but right now LPE seems to have the best fueling solutions for these cars short of using a bunch of meth or port injection. Their 2650 car is making 933 rwhp on E no meth with direct injection. Yes it has $4k injectors, $1500 hpfp for high side, and these dual pumps in addition to a cam but it seems to be working.
2017 ZL1 A10
Dyno/Quarter Mile/Dragy
9.71@141.2 MPH so far.
2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold.
newchevyman is offline   Reply With Quote
Old 12-15-2018, 12:02 AM   #7
KingLT1
KingLT1's Avatar
From what I was told the fuel system is almost 10k installed including the Injectors and HPFP.
Old 12-28-2018, 02:23 PM   #8
DatBrotato
DatBrotato's Avatar
Drives: '18 SS 1LE M6
holy cow lol.
I'm really hoping I can avoid needing those injectors or port injection.
Hoping LT4 Injectors, LPE Hi-Side, Aux pump, & booster is enough for a P1X low boost on E85.
But that dual pump..
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
DatBrotato is offline   Reply With Quote
