![]() Drives: 2017 Camaro ZL1 Join Date: Jan 2018
30% over injectors from kaytech
Hello quick question since i need to do injectors on my ZL1 I was thinking maybe i should just get a set from kaytech that are 30% more flow.
If I get this set can I run full E85 without getting the HP pump? Of course I know I would need tuning and the E85 sensor. EDIT FOR PART https://store.katechengines.com/xdi-...s-30-p880.aspx |
Moderator
Are you doing a cam (and the associated bigger fuel lobe)? If not, the HPFP may not keep up with the bigger injectors. What other mods have you done?
![]() Drives: 2017 A10 ZL1 Join Date: Jul 2011
I run full E85 with headers upper/lower and big gulp , stock injectors.
#5 | |
Moderator
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Unless you plan on adding beyond 250 whp running 93 octane, stock in injectors will get you there (with other supporting mods on high side/low side).
#7 | |
I'd wait till you do a cam otherwise you aren't going to take advantage of the injectors. When you're ready for the injectors we've got some discounts on these and the FIC 30% injectors too. |
#8 |
#9 |
Can I do the injectors now (30%) since im in there already and then do the rest of the upgrades at a later time? If its possible not to have to buy 2 sets of injectors? Just a question coming from my ignorance on this subject. Thank you.
#10 |
If you get the FIC +30 Injectors and LPE HPFP then you will be set to run full E85 without doing a cam. Hit up Pray Performance for more details on the setup.
#11 |
![]() Drives: gas powered Join Date: Jan 2019
On a Zl1 Lt4? I didnt think 100% E85 was possible on a stock fuel system.
#12 |
#13 | |
![]() Drives: 2017 Camero ZL1 Join Date: Nov 2015
If you only have intake and ported TB you should be able to run a blend of E. I would not do injectors and LPE HPFP on stock cam. Meth helps the most but not everyone is willing to do it and that's a whole different discussion. If you're using a reputable shop and tuner I would just heed their advice. Here's a good thread on trying LPE HPFP and injectors on stock cam. https://www.camaro6.com/forums/showthread.php?t=556291
2017 ZL1 A10
Dyno/Quarter Mile/Dragy 9.71@141.2 MPH so far. 2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold. |
#14 | |
![]() Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
