Old 07-06-2020, 01:43 PM   #1
20Bluezl1
2020 zl1 oil change
So i have read alot of post and I'm confused. I'm trying to figure out what is the difference from mobil one 0w-40 dexos 1 vs dexos 2. I look at my manual and it specs out for 0w-40 dexos 2,but I took it to my dealer to get my free oil change and asked them what oil they where going to use and they told me 0w-40 dexos 1 because that is what the vin# pulled up.
So my question is can they use dexos 1?
And from now on I'm changing my own oil and filter, what oil should I use and filter?
Sorry for the long post and also another oil thread.
Old 07-06-2020, 02:05 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
This is the oil you should be using, the filter is an ACDelco PF64:
Old 07-06-2020, 02:09 PM   #3
20Bluezl1
Is it ok to use dexos 1 since dealer is changing it just this time.
Old 07-06-2020, 02:30 PM   #4
2SS Capt
2SS Capt's Avatar
From the owners manual:
Viscosity Grade
Use SAE 0W-40 viscosity grade
engine oil.
When selecting an oil of the
appropriate viscosity grade, it is
recommended to select an oil of the
correct specification. See
“Specification” earlier in this section.
If 0W-40 dexos2 oil is not available,
SAE 5W-30 dexos1 full synthetic
engine oil may be used for
street use.
Specification
Use engine oils that meet the
dexos2 specification.
Engine oils
that have been approved by GM as
meeting the dexos2 specification
are marked with the dexos2
approved logo. See
www.gmdexos.com.
Old 07-06-2020, 02:40 PM   #5
20Bluezl1
So now I'm super confused so the dealer is using the wrong oil? They told me they where putting mobil 0w-40 dexos 1 should the use 5w-30 dexos 1?
Old 07-06-2020, 09:53 PM   #6
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Follow your owners manual, use only what they specify for your 2020 ZL1. This shouldn’t be confusing....
Old 07-06-2020, 10:18 PM   #7
2SS Capt
2SS Capt's Avatar
Honestly, if it were my car and the Dealer's "free" oil change was only Dexos 1, I'd pass and do it myself... (I never took advantage of any "free" oil changes as the few bucks saved wasn't worth risking some idiot at a dealer screwing up my car... My car has 1,900 miles on it and has already had 2 oil and 2 diff fluid changes (at 505 & 1,500 miles), I did them both myself...
Old 07-06-2020, 11:57 PM   #8
FrostySS
FrostySS's Avatar
Drives: 2018 Redline Edition 2SS
They probably misspoke about Dexos 1 vs 2. You're worry way too much about it.
If the 0w40 isn't available then the 5w30 is perfectly fine and is what came in these cars for the first few years.
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD.
FrostySS is offline   Reply With Quote
Old 07-07-2020, 10:07 AM   #9
RWT
RWT's Avatar
Drives: 2020 Camaro RS
This is most likely true as when I review the Dexos1 approved oil list it doesn't have any 0W-40 oils listed.
https://www.gmdexos.com/brands/dexos1/index.html
The Dexos2 list only shows 2 brands of 0W-40 approved, Mobil1 ESP and a Castrol Edge.
https://www.gmdexos.com/brands/dexos2/index.html
So according to these lists, if they are using a Mobil1 0W-40 it's either Dexos2 or not Dexos approved at all. There isn't any Dexos1 0W-40.
JMHO
No expertise implied or expressed
RWT
2020 Camaro RS, V6, 6MT, Satin Steel
2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray
2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic
RWT is offline   Reply With Quote
Old 07-08-2020, 12:24 PM   #10
20Bluezl1
So dealer just called me back and apologized that they give me the wrong information. They said the parts guy give the service writer the wrong oil specs. But they are changing the oil with 0w-40 dexos2.
Old 07-29-2020, 01:29 PM   #11
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Since both "/W40" and "/W30" viscosity grades are approved, as long as they are Dexos2 certified, then you are perfectly fine.
So using 0W40, 5W40 and 5W30 should be perfectly fine.
The difference of the low figure (0 or 5) is only relevant for the flow of the oil in the colder temperatures.
0 is officially spec.ed to flow at lowest ambient temps below -22. So as long as you are not using the car at such low ambients, you can use the 5 spec.
On the other side of the scale, the high Temp. range (especially in hot climate / regions: I.E. FL, AZ, NV, Etc.) it is beneficial to use the 40 spec.
Here is an article which, includes a temperature range chart for the various oil grades:
https://fuelandfriction.com/weekend-...ine-oil-today/
An even better one here:
https://www.motorstate.com/oilviscosity-htm/
Old 07-29-2020, 04:37 PM   #12
tawheed
Drives: 17 ZL1
I can't get over how incompetent dealers are. Just crazy.
tawheed is offline   Reply With Quote
Old 07-29-2020, 06:26 PM   #13
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i just bring my oil to the dealer and pay them to do it and use their filter lol its easier and cheaper that way but i dont run mobil 1 i run torco sr1 5w40
Old 07-29-2020, 07:46 PM   #14
20Bluezl1
That is a great idea also, just ordered a quick jack setup so I can start to do my own maintenance. But I think I'm still going to take it to the dealership for a trans flush.
