Old 05-23-2020, 07:01 PM   #1
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
PDR questions for first track day
Planning to take the ZL1 to the track next weekend for the first time. How do I set up the PDR?
Ie., Do I need to (or can I) download the track info into the recorder so it will show the layout and where I am on the track?
Do I need to mark where the start finish line is? If so, how do I do that?
Any other tips or pointers for using the PDR?
CW3SF is offline   Reply With Quote
Old 05-23-2020, 08:25 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
there are some great youtube tutorials. Basically go on track and mark start/finish line on a warm up lap and it will draw the track map automatically. It uses GPS.
Old 05-24-2020, 07:48 PM   #3
2018$S1le
2018$S1le's Avatar
Drives: '19 ZL1 1LE Summit White M6, PDR
Sweet, thanks I was wondering the same thing about the track image and your position.
2018$S1le is offline   Reply With Quote
Old 05-24-2020, 08:04 PM   #4
cdrptrks
cdrptrks's Avatar
It stores one start/finish per SD card. Make sure you mark it on the track not in the pit lane or grid. If you mark it again it overrides the current one. Easiest to keep separate SD cards per track imo or you can backup/restore the start/finish line file for each track on a single card. Also I use MicroSD in a full sized adapter so I can copy the video to my phone for review between sessions. If you get a card above 32gb you need to format into FAT32 on a computer beforehand. Make sure it is set to Track in the choose video overlay section before you start recording. Put some painter's tape over the mic cutout on the driver's side plastic A pillar near eye level to get rid of annoying wind noise that you get on the recording when driving with the windows down.
Also if you're not familiar with it, look into the performance traction management (PTM) modes available that you might want to try.
https://www.camaro6.com/forums/showthread.php?t=496996
Old 05-24-2020, 10:54 PM   #5
CW3SF
CW3SF's Avatar
Excellent posts. This is what I was looking for. Thanks.
Old 05-27-2020, 10:04 PM   #6
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
It's annoying you have to mark the start/finish each time.
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 05-28-2020, 07:10 AM   #7
cdrptrks
cdrptrks's Avatar
The SD card stores the most recent marking so if you keep a separate card for each track then you only need to mark it one single time.
Old 05-28-2020, 09:32 AM   #8
nicktechla
nicktechla's Avatar
oh really? interesting, thanks. I'll have to see next track day.
IG: 2fast2nick
-- Current --
-- Past --
Old 05-28-2020, 09:54 AM   #9
juice3
juice3's Avatar
Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V
SD Cards aren't always formatted correctly. Do a test run before you track day.
juice3 is offline   Reply With Quote
Old 05-29-2020, 04:33 PM   #10
CW3SF
CW3SF's Avatar
Had a good first day at the track. But I did have a couple of issues with the PDR.
We did 30 min sessions. For some reason the PDR kept asking me to mark the finish line. With a lot going on inside the car (first time) I mostly just ignored the messages and drove haha.
Also at one point the PDR screen went blank and I finally got it working again by removing the SD card several times.
Track was a little busy so it was hard to get a solid full throttle lap on all the way around. Had a blast though. Will definitely go back.
http://youtu.be/dRxWkBYf8lA
Old 05-30-2020, 06:33 AM   #11
PROMETHEUS
PROMETHEUS's Avatar
I am certainly no racecar driver, however, you are shift points need to be adjusted. I noticed you are shifting at about 4K RPMs, take it to the limit or close to the limit each time....6.5K. Watch your heads up display, there are side markers that go from green to yellow to red. You really want to be in the yellow/red, when you shift. You will find you will be shifting less and going much faster/smoother around the track.
Old 05-30-2020, 07:42 AM   #12
CW3SF
CW3SF's Avatar
Thanks for the pointers. I was intentionally taking it easy while I learned the track. It was my first time out there.
Old 05-30-2020, 05:37 PM   #13
PROMETHEUS
PROMETHEUS's Avatar
Old 05-30-2020, 05:53 PM   #14
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Great post. For sure do a test before your track day to make sure everything works. I always use a 32GB sd card and never had to format. Beware there is a very small slide on the side of the SD adapter, if it's in the wrong position you won't be able to record because that's the write protect switch.
