![]() Drives: 2016 2SS Join Date: Mar 2018
Replacing a rear wheel stud
Is there a simpler way to do this without ripping everything apart? Thanks in advance.
Anybody?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
no there isn't but the job isn't that difficult either. Remove the 36mm nut, toe arm, 2 top suspension arms, and sway bar link. The bearing assembly with the studs is attached by three bolts. You can likely bang out the studs with a hammer at this point. Reinstall studs with a lisle stud install tool and an impact.
#4 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
if you can do that then you are amazing...the bolts are almost completely shrouded by the axle shaft and the approach angle is not direct. It looks like a recipe for a rounded bolt if this isn't fully disassembled. I tried but it ends up being more efficient for direct access to fully disassemble.
#6 | |
#7 |
![]() Drives: 2019 SS 1LE Join Date: Jun 2018
Anyone know the torque specs for the hub bolts and the axle nut?
#8 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
Hub bolts: 96 lb-ft w/ locktite
Axle nut: single use and the washer (11611965) should be replaced. AllData says 185 lb-ft, folks on here say 199 lb-ft, w/ locktite
#9 |
I replaced one side last weekend. I had broken a lug the weekend prior. It really was not too bad. I pulled the toe arm (I have an SPL), top two control arms, and used a three arm puller to push the axle back enough to get a wobble socket on my stubby mid torque milwaukee to remove the hub. replaced the studs with ARPs and reassembled. I did it over two days just because I was busy. Now I can likely do the other side on the rear in an easy two hours.
Waiting on new hardware was longest part of the endeavor. |
#10 |
![]() Drives: 2021 LT1 RS Auto, 2018 ZL1 1LE Ext Join Date: May 2020
Order part
Where did you order the Axle nut and washer from?
#11 |
Geoff
local dealership or you can get from a GM parts seller online
11612295 outer axle nut 11611965 washer
#12 |
![]() Drives: 2019 ZLE Join Date: Jul 2020
Do you need a rear end alignment after replacing rear studs?
#13 |
BLEW BIU
Drives: 2018 2SS 1LE Hyper Blue Join Date: Oct 2017
If you removed any of the suspension parts, I most certainly would get an alignment, especially if you are going to track it after.
I just replaced my rear studs this past weekend without removing any of the suspension bolts. If I can do it, anyone can (as I am not a master mechanic). Did it on jack stands in my garage. As mentioned previously on here, sliding the axel out just a bit gives you enough room to get a socket onto the hub bolts. I was afraid getting the bolts back in would be really challenging since it's difficult seeing the holes from under the car, but if you put the bolts in prior to reinstalling the hub, you can see the holes from the outside and get them lined up that way. Definitely not the most fun thing I've ever done, but doable. Just take your time. Also, breaking the axel nut loose required some convincing. Lol. Ended up using some WD40 Penetrate and a cheater bar (jack bar over breaker bar) to finally get it to loosen up. Last edited by Texan4iu; 10-04-2024 at 11:02 AM. |
#14 |
![]() Drives: '23 2SS1LE Join Date: Sep 2022
Old thread I know, but I just broke a rear stud at the track. For those who have replaced them, are you sticking with stock parts, or is there something better?
TIA, Larry |
