Old 05-04-2020, 03:45 PM   #1
ZRacerLE
ZRacerLE's Avatar
Drives: The DSSV Twins: ZR2 and ZLE A10
Brake bleed corner order
What corner order do I use with these cars for bleeding the brakes?
ZRacerLE is offline   Reply With Quote
Old 05-04-2020, 03:50 PM   #2
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
If I am not mistaken, Right Rear, Left Rear, Right Front then Left Front, that's usually the norm for brake bleeding.
warren3537 is offline   Reply With Quote
Old 05-04-2020, 04:03 PM   #3
ZRacerLE
ZRacerLE's Avatar
Makes sense since reservoir is on driver's side. Just wanted to be sure before I dive in. Thanks!
Old 05-04-2020, 06:25 PM   #4
PROMETHEUS
PROMETHEUS's Avatar
Yep, that is the order!
Old 05-04-2020, 09:29 PM   #5
warren3537
warren3537's Avatar
No problem glad to help
Old 05-04-2020, 09:39 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
that is the correct way in my mind too and the way I've always bled. Furthest from the master cylinder to the closest. However, the shop manual states something different than expected: https://www.camaro6.com/forums/showthread.php?t=536984
Old 05-04-2020, 10:59 PM   #7
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Actually in modern cars with anti lock brakes the proper starting corner is the one futhest from the ALM.
In some cars the master cylinder and the anti lock brake module are on the same side. On the 6th Gen the ALM is on the right side.
Proper sequence in 6th Gen is LR-RR-LF-RF.
2018 ZL1 1LE sw/PDR
Old 05-04-2020, 11:12 PM   #8
Stephen12ZL1
Drives: '21 ZLE A10
hmmm...
Old 05-04-2020, 11:17 PM   #9
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
But the master still remains in the same spot...wonder if the service manual is assuming/expecting you to bleed the ABS module (which few folks do? IE isn't a Tech II required?)
I don't think it really matters.
Tim M is offline   Reply With Quote
Old 05-05-2020, 07:36 AM   #10
Stephen12ZL1
Drives: '21 ZLE A10
tech 2 or scan tool with an ABS bleed option to cycle the electric motor. I'm not certain the service manual is assuming the ABS pump is being cycled.
Old 05-05-2020, 04:18 PM   #11
HypeBlueZL1
Drives: Chevrolet Camaro ZL1
I just did this the other day. The correct order is:
Right Rear
Left Front
Left Rear
Right Front
Each caliper should do the inner first then the outer. It's this way on a lot of GM products.
HypeBlueZL1 is offline   Reply With Quote
Old 05-05-2020, 05:08 PM   #12
ZRacerLE
ZRacerLE's Avatar
Right Rear
Left Front
Left Rear
Right Front
Alright, glad I asked. I was afraid something non-intuitive might be going on...
Old 05-08-2020, 10:20 AM   #13
DFW_Muscle
Drives: 2018 Chevrolet Camaro ZL1
Right Rear
Left Front
Left Rear
Right Front
Where did you come up with that variant of the order from?
DFW_Muscle is offline   Reply With Quote
Old 05-08-2020, 11:33 AM   #14
HypeBlueZL1
It's in the service manual. My C5 corvette and my CTS-V have the same bleed order as well.
