![]() Drives: 2017 ZL1 Camaro Join Date: May 2018
Bleeding brakes - what is the proper caliper order?
I have a track day soon and I need to flush my brakes on my 17 ZL1 and can't seem to find consistent info on which order the brake calipers get bled. On my 4th gen Trans Am it was always passenger rear, driver rear, passenger front, driver front. I've purchased the Motive power bleeder and plan to use it dry and only for pressure while keeping the reservoir topped off between corners, I have motul 600 fluid that I plan to use.
I've never had a car with inner and outer pistons on each corner either so can anyone who tracks their car and bleeds brakes often give me some tips? |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
This is going to be a shock. It kind of doesn't really matter what the order is. All 4 corners have their own line downstream of the ABS module. Whichever you pick first, that's the one that'll take the longest as you have to first push new fluid from the reservoir to the ABS module inlet.
For those that "must" do it from longest line to shortest, it's LR, RR, LF, RF. For each caliper, it tends to make sense to do the outboard bleeder first as that's the larger fluid volume and it will also inherently bleed part of the inboard passages simultaneously. Probably the most important advice in all of this, is to ensure you twist up a paper towel really tight to a point and get the extra fluid out of the bleeder once you're done. It holds more than you may think, and after your first track session it'll end up all over your calipers. Either that or you didn't tighten the bleeder enough; these stupid Brembo bleeders need more torque than every other brand/model caliper I've ever touched.
Opus13
Drives: 2017 Camaro 1SS, Black Join Date: Jul 2017
Remember reading this awhile ago.
QUOTE=Mrfixxit7;10155673]Hey guys FYI, I was reading through the service manual and it states the sequence for bleeding brakes is: 1. Right rear - inner then outer 2. Left front - inner then outer 3. Left rear - inner then outer 4. Right front - inner then outer I know most people are using a different sequence[/QUOTE]
"My entire life in one sentence:
It didn't go as hoped, but that's okay" Opus ie. Berkeley Breathed. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
when i got my phastek ss lines and fluid in my car and put on the shop had such a bitch doing my brake lines lol they told me they had to do it like 3 times in different directions in each time
#5 | |
BAMF SS
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
Thanks for the info guys, I'm going to give it a shot this week.
#7 |
retired badass
furthest from the reservoir first learned it in school and still use the same method today.
2016 2SS M6 Black
Kooks 2in headers/full exhaust, Hurst short shifter, Dsx E85 kit, BMR solid engine mounts. Retired USMC |
#8 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
...that's what I saw, too... |
