Old 05-01-2020, 10:50 PM   #1
DuoMaxwell007
Drives: 2017 Chevy Camaro 2LT
What kind of scratch?
So there was a scooter incident with the side of my driver side door, a friend says its no that bad and can just be cleaned/wiped off. So after he tried that (for 15 mins I might add.... "not that bad" shouldnt take 15 mins but whatever) so now where the scratch is (this is my first time seeing it) the rest of the door is one color and the scratched area that was cleaned is the same color but its a different shade of that color, so I dont see metal or white from paint being peeled or anything but 99% of the door is one color then the line where the scratch should/would be is a different shade of that color so you can tell something happened and someone tried to clean/fix it.
My question is would that fall under a clear coat scratch, primer scratch or a paint scratch?
DuoMaxwell007 is offline   Reply With Quote
Old 05-01-2020, 10:54 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I'm guessing (without seeing pictures) he rubbed through the clear coat...
2SS Capt is online now   Reply With Quote
Old 05-01-2020, 11:00 PM   #3
DuoMaxwell007
so assuming youre right. If I wanted to get those colors matching up again is that an easy and inexpensive fix?
Old 05-01-2020, 11:02 PM   #4
2SS Capt
2SS Capt's Avatar
Likely at least painting the panel...
Old 05-02-2020, 12:07 AM   #5
KirkH
Post a good picture and I can give you an idea of what it will take to fix it.
