Old 04-24-2020, 03:12 PM   #1
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
front rotors issue see inside
What do you make of this? You can barely feel it but its there, like pitting or something, only 7500 miles I like to give it the beans sometimes but never on a road course.
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 04-24-2020, 03:17 PM   #2
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Casting defect in the metal. Surprised it hasn't cracked even though you don't track it. I'd try to get that replaced under warranty if I was you.
Old 04-24-2020, 04:05 PM   #3
TWG1
TWG1
Drives: 2019 Camaro ZLE
Could also be pitted from rust under the pads if put away wet. I made mistake of washing and garaging and two weeks later I left a 3’ skid mark getting out of garage before wheel broke free. Mine has slight pits where pads were, but not that bad.
2019 ZLE M6
2019 ZL1 A10 (Sold)
1967 Jaguar XKE Series 1 Roadster
2021 F150 Powerboost (on order)
TWG1 is offline   Reply With Quote
Old 04-24-2020, 04:47 PM   #4
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
^^what he said
Old 04-24-2020, 05:55 PM   #5
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Washed the car a few days ago, used it everyday since. The way I drive it, the rotor should be clean in 10 min of the first trip, LOL
Old 04-24-2020, 10:23 PM   #6
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Did you try hitting it with a sanding block and some 400grit paper?
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 04-26-2020, 08:30 PM   #7
Alain
Alain's Avatar
was the picture in the original post deleted? I can't see anything.
2018 ZL1 1LE/Red hot
Old 04-26-2020, 08:36 PM   #8
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
no, picture is still there.
Old 04-26-2020, 09:52 PM   #9
AZ_1LE
Drives: 2019 ZL1 1LE
That's 100% a warranty issue, not normal "wear and tear."
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 04-27-2020, 08:25 AM   #10
TheRealJA105
Drives: 2013 C6Z06
That's not caused by surface rust. You can see the metal is porous, from air remaining during the casting process.
Old 04-27-2020, 10:17 AM   #11
Badmojo
aka BeastZL1
Badmojo's Avatar
+1 this is a casting defect, porosity
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 04-27-2020, 10:36 AM   #12
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
This^^^
NOT this.
driven2exceSS is offline   Reply With Quote
