Old 04-11-2020, 10:52 PM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
zl1 brakes on.
Front 6 piston Brembos 15.35" rotors
Rear 4 piston Brembos 14.4" rotors
Amsoil Dominator DOT4
Goodridge stainless brake hoses.
Old 04-11-2020, 11:16 PM   #2
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
driven2exceSS is offline   Reply With Quote
Old 05-10-2020, 05:28 PM   #3
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
Did you use the supplied track day backing plates or order ZL1 backing plates?
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 05-10-2020, 11:16 PM   #4
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Nice! Debating doing this myself.
soloknight6 is offline   Reply With Quote
Old 05-10-2020, 11:25 PM   #5
JCunningham
Drives: 2017 2SS M6
i bought the ZL1 plates.
Old 05-10-2020, 11:30 PM   #6
JCunningham
Drives: 2017 2SS M6
i even bought the zl1 rear plates too. when i bought them there was 2 different part numbers for the SS and ZL1 plates. I didnt notice until i went to put the 1st on on that what i got was the same plate as the one i was taking off. Now they both have the same part numbers. they are smaller by probably 3/8" then the rotor.
Old 05-11-2020, 12:50 PM   #7
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
This is the one on the right side, same smaller dia
yea it's filthy, lots of construction around here.............
