Old 03-19-2020, 12:12 AM   #1
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
Question What's the best way to clean exhaust tips?
In the attached picture I cleaned the exhaust tips with Simple Green and a soft scotch brite pad. It had little impact.
My next direction is rubbing compound and a power cone.
I'm trying to not scratch up the exhaust tips, but cleaning chemicals aren't getting it done.
Any thoughts, or proven methods?
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 03-19-2020, 12:23 AM   #2
I use Nevr Dull on a regular basis and occasionally Mother's Mag and Aluminum polish, they work perfectly well and make a very quick job of exhaust tip cleaning.
Old 03-19-2020, 01:42 AM   #3
JoeCamaro444
JoeCamaro444's Avatar
Drives: 2018 2SS M6 Hot Wheels Camaro
This 👍🏻
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars:
2017 1SS Nightfall Gray Metallic w/A8 and NPP
1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps.
JoeCamaro444 is offline   Reply With Quote
Old 03-19-2020, 07:13 AM   #4
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
I always clay first then I use Metal Polish 1 & 2 with a MF pad.
If the tips aren't real bad you can get by with just MP 2.
https://adamspolishes.com/collection...metal-polish-1
https://adamspolishes.com/collection...metal-polish-2
Adam's Polishes is offline   Reply With Quote
Old 03-19-2020, 07:35 AM   #5
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I painted the inside of my tips three years ago and have never cleaned the inside since. They look today just as good as the pics I took in this thread three years ago:
https://www.camaro6.com/forums/showthread.php?t=471821
note: You will also notice I painted the muffler suitcase black as well. That made the shiny trash can look just disappear.
476 rwhp/440 rwtq (sold)
Old 03-19-2020, 08:31 AM   #6
oftenimitated
Drives: 2004 Honda Civic+2011 Camaro 2SS
very fine steel wool and metal polish works well for me
oftenimitated is offline   Reply With Quote
Old 03-19-2020, 08:50 AM   #7
grampa_ss
grampa_ss's Avatar
I got tired of it real quick. I have black tips now.
Old 03-19-2020, 09:03 AM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
I've used soap and water (Adams Car Shampoo, Carpro Reset) and a low-pile walmart cheapo MF towel since day 1. Hydrophobic coatings and spray sealants really help a lot here. A quick shot of Magic Elixir* Quick Detailer has avoided any build up.
Yours are to the point where a mother's powerball/cone and some aluminum polish is needed, but will brighten them up quick.
* Carpro Ech20 : Carpro Reload : Distilled water in a ratio of 1:4:20.
Old 03-19-2020, 10:30 AM   #9
KirkH
Steel wool and metal polish like posted above.
Old 03-19-2020, 11:09 AM   #10
SSport16
SSport16's Avatar
I use a cone pad for my cordless drill with a good polish. I used to use a metal polish but now use Carpro Essence instead then put some Reload on the inside and outsides of the tips. Clean them in between with the Ech20/Reload/distilled water quick detailer mixture.
Old 03-19-2020, 11:21 AM   #11
harner
harner's Avatar
Drives: 2018 ZL1 A10
I coated my tips, so usually do a rinseless or detail spray mist and wipe off. Customer cars get metal polish and steel wool (grade depends on condition, but always end with 0000).
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail
OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors
1994 Trans Am LM7/CPT 4L60E/9"
1987 IROC
2006 Silverado
harner is offline   Reply With Quote
Old 03-19-2020, 12:24 PM   #12
Abubaca
Abubaca's Avatar
Drives: 2016 SS
After the car is done being washed, I'll normally grab an old MF towel and wash the tips off real good. Just car soap and water. Then I'll normally hit the outside of 'em with my dry tower/drying aid as the last thing before being done with drying. Been doing that for years and years. I'll use Never Dull a few times a year, but if you wash 'em regularly, it's really not needed.
Of course, this would all depend on how often you drive. Mine isn't a DD. -that being said I use the same technique on my DD GMC Sierra. I just don't wash the inside of the polished tips. I leave 'em black/dirty.
Abubaca is offline   Reply With Quote
Old 03-19-2020, 12:34 PM   #13
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
this stuff with a rag works great!
Old 03-19-2020, 12:40 PM   #14
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Simple green and a rag,
ssmofo is offline   Reply With Quote
