Old 10-31-2016, 03:09 PM   #1
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Painted exhaust tips: updated with before and after
These things were always dirty no matter how much I cleaned them. So I painted the inside area flat black with hi-temp paint. We'll see how this holds up.
Update: See post #14 for before and after photos
476 rwhp/440 rwtq (sold)
Old 10-31-2016, 04:43 PM   #2
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Looks good,
Old 10-31-2016, 04:45 PM   #3
JBinSD
Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT
Looks great, are these (tips) easy to remove? Was thinking of painting the exteriors black as well, but heat may be an issue. . .
JBinSD is offline   Reply With Quote
Old 10-31-2016, 05:34 PM   #4
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Engine paint should do it. They handle 550 degrees. No way the tips hit that mark. Although I'm not sure if painting on chrome changes how well it sticks.
Obzen is offline   Reply With Quote
Old 10-31-2016, 07:58 PM   #5
SSDan
SSDan's Avatar
They are welded so it would take some work to take them off and on. I used high temp paint so I am not worried about heat. I only cleaned the tips before painting and did not prep the surface by sanding or otherwise. I chose to do that in case I don't like this later or it gives me problems I can use paint thinner and remove the flat black paint and go back to the original chrome.
Old 10-31-2016, 08:03 PM   #6
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You won't have any problems, I painted the interior of tips with high temp flat black several times without any prep. Nothing happens because the surface is rather rough to begin with , as long as you're cleaned it up well to begin with. If anybody else is going to do this, use acetone liberally to clean the interior.
Old 11-01-2016, 10:42 AM   #7
Camaro_49
Drives: Camaro
Any more pictures from different angles please?
Camaro_49 is offline   Reply With Quote
Old 11-01-2016, 11:24 AM   #8
KirkH
Did you guys use spray paint or a brush?
I like the idea of hiding the exhaust oily dirt.
Old 11-01-2016, 01:57 PM   #9
JBinSD
so did you just tape it off and spray right on the car? I looked at the tack-welds holding the exhaust tips on, not really something I'm capable of messing with, but might try to tape off the whole area and paint it flat black, inside and out. . .
Old 11-01-2016, 02:27 PM   #10
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Here's how I have done it, with paper and painters tape ,tape off the valance /rear skirt. Then tape the outside of the exhaust pipe tip, taking care to make sure the edge is uniform around the rim. Take the tape a bit inside the rim.Using a spray paint can Use light and quick spritzes until the whole thing is covered on the inside, don't worry about getting it real even, because it levels well when it's high temp flat black. Wait 20 minutes and do another coat .Remember no one is going to get down on their knees to inspect your work. Except you…
Take note what I said above about an acetone scrub clean up before painting.
Old 11-01-2016, 05:27 PM   #11
SSDan
SSDan's Avatar
I'll try to take one tomorrow in better light.
What Glen e said.
I'll add that to cover the exhaust tips on the outside I cut the toes off an old pair of crew socks and slid the sock tubes over the pipes. Much easier for me than a bunch of paper and tape around the pipes except to make the clean edge with tape as Glen states.
Old 11-01-2016, 08:37 PM   #12
tcbracing
tcbracing's Avatar
Drives: 2017 Camaro 2SS Convertible
...go back to the original chrome.
Just to clarify, the tips are actually stainless steel. If they were chrome, nothing would stick to them very well. Your little strips above the front LED's on a SS are chrome (plated plastic).
BTW, the tips look great!
2SS Convertible, Mosaic Black, Red Hashmark, Adrenaline Red Interior, A8, NPP, MRC, 56R Wheels
6/6/2016 Dealer entered order
6/7/2016 Received order # TMXWV0 - Status 1100
6/11/2016 Status 3000
6/22/2016 Status 3400 - TPW 6/27
6/29/2016 My car is born!!
7/13/2016 Status 4300
7/14/2016 Status 4B00
7/18/2016 Status 4200
7/25/2016 Status 4800
7/29/2016 Status 5000 - Drove home!!
tcbracing is offline   Reply With Quote
Old 11-01-2016, 10:06 PM   #13
SkipNWis
SkipNWis's Avatar
Drives: 2016/SS Has had 4 Gen 5's
Yep come spring mine are going to be Black. But doing both inside and outside looks good
SnoWhite
SkipNWis is offline   Reply With Quote
Old 11-02-2016, 01:10 PM   #14
SSDan
SSDan's Avatar
Here is before and after. It creates the illusion that the inside diameter is bigger as a bonus to avoiding the dirty tip look all the tip.
