Old 03-14-2020, 09:48 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
ZL1 A10 Differential removal tips
This isn't incredibly difficult but a few things need to be stated.
The independent differential pumpkin (center section) is held in place with three fastening points: one accessible from the rear of the vehicle: a 24mm headed M16 x 2.0 bolt which goes through the subframe and two forward bolt/nut combo which require an 18mm ratchet & wrench.
You must first remove the axle retaining bolts on each side which works easiest with an impact & extension with appropriate torx (star) socket. You will need to put the car in neutral and rotate the axle to gain access to all of the bolts. They are pretty well "loctited" in position with GM green loctite so be careful and don't round the heads. I removed the wheel speed sensor and repositioned the upper control arm to get straight line access to the bolts.
You must remove the cooling lines under the diff. After pushing the black plastic rings away, use a pick to release the retaining clips in all four positions. Remove the 10mm retaining bolt. Be careful not to lose the little clips. Remove these lines and set aside. Unplug the e-diff weatherpack and unplug the passenger suspension position sensor.
There is a control module that has two 18mm sized lines that must be removed. These lines continue through the subframe and have a peculiar Eaton quick connect at the differential. A small trim removal tool fork needs to be inserted between the rubber part and the differential. If it takes a lot of force, you are doing it wrong. Once the appropriate sized fork is placed there, it simply pops off.
Hopefully this info will be useful to someone. Thought this info was worthy to share.
Old 03-14-2020, 10:09 PM   #2
Stephen12ZL1
Drives: '21 ZLE A10
probably wondering why I removed the differential...the top bolt broke on track about 6 months ago and the track service "fixed" it. In the process, they stripped the aluminum housing on the top bolt so I am going to install a thread insert. No way to do this without dropping the entire center section. Pics are ugly. I knew something was wrong because there was a persistent clunk which was metal on metal and very aggravating.
Old 03-15-2020, 11:56 AM   #3
L78toLT1
L78toLT1's Avatar
While it's basically a non issue as either option will outperform the original, helicoils are slightly stronger than timeserts based on testing we did in one of my materials courses back in the day. If you haven't already purchased the timeserts can get the helicoils cheaper, I'd go with them.
Baby Blue
Old 03-15-2020, 12:09 PM   #4
Stephen12ZL1
Drives: '21 ZLE A10
Weird thing is I was told exactly the opposite by a local machinist
Old 03-15-2020, 10:00 PM   #5
Stephen12ZL1
Drives: '21 ZLE A10
thread repair pics
Old 03-17-2020, 12:38 PM   #6
TWG1
TWG1
Drives: 2019 Camaro ZLE
Nice work! Aluminum: great for drivers, not so great for mechanics. I’m actually surprised how seldom aluminum seems to strip these days. Back in my motorcycle days, it seemed a routine occurrence to fix threads.
Either the materials/engineering have gotten better, or I’ve become less of a meathead mechanic.
2019 ZLE M6
2019 ZL1 A10 (Sold)
1967 Jaguar XKE Series 1 Roadster
2021 F150 Powerboost (on order)
TWG1 is offline   Reply With Quote
Old 03-17-2020, 05:21 PM   #7
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
I remember on my old 1975 Honda CB400F when doing the valve cover nearly all the threads would come out just by turning the bolts by hand, no tools necessary.
mrgoodbytes is offline   Reply With Quote
Old 02-11-2024, 06:10 PM   #8
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Reviving an old thread, but what did you do about any fluid loss from the elsd module when disconnecting those lines. The transmission cooler lines are easy and they just take trans fluid from the trans, but the elsd motor I've been told uses a hydrolic fluid in a sealed system.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 03-13-2024, 02:42 PM   #9
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
I'm also interested in the bleeding procedure for the ELSD pump
