Old 03-09-2020, 04:20 PM   #1
chambers3214@yahoo.com
Drives: 2017 camaro ZL1
What oil y’all recommend I use for my 17 ZL1?
My car was built few months ago I have BTR stage 3 cam, whipple supercharger, I basically went thru the whole engine top to bottom. What kind y’all suggest I should use on this kind of build
chambers3214@yahoo.com is offline   Reply With Quote
Old 03-09-2020, 04:50 PM   #2
Tricksta
Tricksta's Avatar
Drives: 2018 ZL1 A10
0W-40.
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust
Tricksta is offline   Reply With Quote
Old 03-09-2020, 05:08 PM   #3
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Mobil 1 0W-40 ESP like everybody else.
However, 5W30 will still work fine. As will 15W50 for track use.
Old 03-09-2020, 05:13 PM   #4
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Originally Posted by Tricksta View Post
0W-40.
At this point with all your mods, you dont need to follow GM warranty guidelines for oil. You must be making a lot more power over stock, I'm guessing +150 at least.
With more power comes more friction and heat, even if the Whipple keeps the IATs down.
I have no warranty breaking mods and run my ZLE at the track. I often leave the M1 15w50 in for awhile after a 2 day event. It seems to stop all oil consumption, and I live in Los Angeles where it never gets below 50 F. The LT4 is happy with this oil.
You should ask the shop that built your car what they recommend, for heavier protection you can use Valvoline Dexos 2 5w40 or maybe non-dexos M1 5w50 (Rally Formula)--this one is still great for cold start in low ambient temps. They also make M1 Racing 0w50.
SFV1LE is offline   Reply With Quote
Old 03-09-2020, 05:44 PM   #5
Canadian ZL1
Canadian ZL1's Avatar
Drives: 2017 ZL1, 1995 Trans Am
0W-40
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof
Canadian ZL1 is offline   Reply With Quote
Old 03-09-2020, 06:33 PM   #6
dbvettez06
Drives: 2001 corvette Z06. 2018 ZL1
Normal driving with occasional full throttle = Mobil 1 5x 30. As GM says.
dbvettez06 is offline   Reply With Quote
Old 03-09-2020, 06:53 PM   #7
Tricksta
Tricksta's Avatar
Gm says 0W-40 now. This is what they will get by default at a dealership.
Modifications
Old 03-09-2020, 07:08 PM   #8
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
chambers, I would check with the guys in the shop that built your engine as to their recommendations of what grade of oil to use unless you did the build yourself! If you did the build then you can determine which grade/brand of oil you might want to use using the replies from the folks here!��
