Old 03-03-2020, 08:35 PM   #1
Dixie ZL1
NOXQCES ZL1
Drives: 2017 Camaro ZL1
BMR Toe Bar Noise
Has anyone else experienced cabin noise from BMR toe bars? The rear end of my ZL1 is all BMR and through painful elimination of variables I’m down to toe bars and sway bar end links.
Appreciate your input.
Dixie ZL1 is offline   Reply With Quote
Old 03-04-2020, 04:00 AM   #2
Mark R
Drives: 2018 ZL-1
I just bought and installed BMR toe bars, and was not impressed with the looseness and excessive clearance between the cone shaped spacers and the bolts. I had a friend machine all new ones with much tighter clearance, and I have no noise. I suspect that is your issue.
It is the first issue I have had with BMR quality ever. I also added rubber boots over the heim joints at the end, per BMR recommendation.
Old 03-04-2020, 04:14 AM   #3
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
I ordered these a few months back (around/after Christmas) and while awaiting time to install them I noticed the bolts in the spacers were a hot dog in a hallway. I measured the spacer bore and the bolts and contacted BMR and they said those were the wrong bushings for my car, they sent a new set and the fit was much better. My contact there said they were pulling all stock to check for the correct parts, I got the vibe I wasn't the only one.
Warrior102 is offline   Reply With Quote
Old 03-04-2020, 07:55 AM   #4
ICTsccaCamaro
Drives: 2018 ZL1 1LE
The factory rear toe links (at least on the ZL1 1LE) are a rubber boot covered heim joint style end, there is zero give or deflection in the arm due to this, it blows my mind that people will take off this perfectly good part and replace with with a poorly designed aftermarket link and pay money for it?
ICTsccaCamaro is offline   Reply With Quote
Old 03-04-2020, 09:51 AM   #5
Mark R
Drives: 2018 ZL-1
I measured the clearances then called them. I did not get the wrong spacers, per BMR. But they were still too loose, so I had new ones made that were really tight.
Old 03-04-2020, 09:54 AM   #6
Mark R
Drives: 2018 ZL-1
On the regular ZL-1, they are not heim joints. The whole idea of the BMR toe rods is to eliminate the eccentric adjuster and the one-time use bolt, because the stock toe is kept in alignment from the clamping force of the bolt. Once the BMR rod is bolted in, the toe is adjusted by lengthening or shortening the rod by turning it.
Old 03-04-2020, 12:44 PM   #7
Dixie ZL1
NOXQCES ZL1
My car is aligned at least 2X / year and sometimes more often depending on events. The adjustable toe bars eliminate the need to replace toe link bolts at every alignment and my alignment tech loves them due to ease of adjustment.
Everyone has opinions about the value of aftermarket parts, but these are worth the small investment and pay for themselves quickly.
Old 03-04-2020, 02:02 PM   #8
ICTsccaCamaro
I have aligned my car 4 or 5 times at this point and have never replaced the bolts. I use a paint pen to mark my bolt locations and have never had one move.
Old 03-04-2020, 02:05 PM   #9
Dixie ZL1
NOXQCES ZL1
I believe you and everyone has their own risk tolerance. The bolts are TTY and one use according to GM, so for me it’s not worth losing a toe bar during a track event.
Old 03-04-2020, 04:05 PM   #10
L78toLT1
L78toLT1's Avatar
Does anyone know if the ZLE toe link is compatible with SS/SS1LE/ZL1? If so this would probably be a better option than the BMR
Baby Blue
Old 03-04-2020, 04:27 PM   #11
Dixie ZL1
NOXQCES ZL1
BMR is replacing all four heim joints at no charge and expediting shipping. Great customer service. A couple new outer TTY bolts from GM and issue will be resolved.
Old 03-04-2020, 04:39 PM   #12
Mark R
Drives: 2018 ZL-1
Nice!!
Old 03-04-2020, 05:50 PM   #13
amolaver
Drives: 18 ZL1 E90M3 E36M3 SM NCMX5
+1
amolaver is offline   Reply With Quote
Old 03-05-2020, 08:18 AM   #14
ICTsccaCamaro
At least in the 5th gen world they were swapable, I would assume since all of our cars have the same suspension design they would swap just fine.
