#1 | |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Mar 2017
Stock dyno test and First mods for the ZL1 1LE
Hi! I just took the ZLE to the dyno to do some test runs before installing the first mods. In the video you will see the numbers(heartbreaking) and how mods looks. This is a 2 part video so I will upload here the second part as soon as I can.
Enjoy! https://youtu.be/Z6tHyrZboWg |
![]() Drives: 2018 ZL1 1LE Join Date: May 2019
That is supppper low power stock. What the heck.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
![]() Drives: '19 ZL1 1LE Join Date: Feb 2019
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Mustang dynos are always the lowest or one of the lowest reading, so that is probably the reason. What is the octane of fuel there? Maybe mix in 4 gallons of 100 unleaded and test again--this will eliminate fuel as an issue. Were boost and AFR normal?
Also, you said it was getting some knock and tuner said maybe because it's tuned rich--knock is the OPPOSITE thing you get when rich, knock results from lean AFR (vs. rich AFR), high boost, and/or too much timing. That's why GM tunes the cars rich, to avoid knock in these monster SC motors when customers get bad fuel or even choose 87 at the pump I would question the tuner's knowledge if they actually said that, it's a basic tuning 101 thing Last edited by SFV1LE; 12-12-2019 at 05:43 PM. |
I think the fuel is the issue, ive never seen a dyno under 500whp before I was even dynoed stock on a mustang over 560. Sure there are variances but the car sounds lazy for some reason, like its taking its time to rev. As long as you are happy though thats all that matters, they are amazing cars!
#7 |
New to GM
Drives: 17 ZL1 91 LX 5.0 Join Date: Jun 2019
How about posting the numbers here for those not interested in watching a youtube video?
#8 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Dynos can also be manipulated.
#9 | |
#10 | |
Also, maybe I didn't translate correctly the part that he talk about the car running rich. He didn't say that it was knocking because it running rich. I asked what he saw and he mention that it was rich and it was knocking a little. But he is not the tuner, he is the mechanic and he was just taking the logs because the tuner had to go out of the shop due to an emergency. Also like I mentioned before, there's another ZL1-1LE that was tuned in this dyno and the stock numbers were the same. |
#11 | |
#12 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
That is the lowest I have seen. Hoping it is the dyno and not the car.
#13 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Extremely low for a stock ZL1!
#14 |
